tee
Mar 25, 2012 15:48:32 GMT
Last Edit: Mar 25, 2012 15:55:43 GMT by tee
T
Mar 25, 2012 16:32:39 GMT
Have you replaced the regulator?
tee
Mar 25, 2012 17:05:03 GMT
yep I switched regulator and tested charge on battery, it was still high at around 17/18
T
Mar 25, 2012 17:36:45 GMT
Where/how did you test the battery? With a brand new regulator you shouldn't be getting that into the battery though most regs are adjustable I believe.
tee
Mar 26, 2012 18:22:46 GMT
Had a guy who reconditions parts test it out with his meter reader thingy, tested it first with old reg and it was 17, switched wiring to new reg and it was the same. If alternator was faulty could that be pumping too much charge to battery or is charge solely controlled by regulator?
T
Mar 26, 2012 18:58:45 GMT
solely by the regulator. Sounds like you have other issues if a new regulator is showing the same symptoms. Definitely wired correctly?
tee
Mar 27, 2012 16:43:18 GMT
That's the thing I'm unsure about wiring, it says high medium and low on the regulator and for some reason there's wires on all 3, but I was running it like this for some weeks before the problems started
T
