johnna
Mar 29, 2012 17:31:32 GMT
Hello folks, my wife's car came with mcgard lockers on it. They have a patterned head and a spinning collar.
It didn't come with a key or a code though. BOOOOOOOOOOOOO!!!!!!!!!!!!!
So, my thoughts are: Mig on a nut. Mig the collar to the bolt and whack a socket over. Split the collar and whack on a socket.
Any other ideas?
PMs most welcome!
Thanks in advance.
Mar 29, 2012 17:35:39 GMT
Any of those pretty much. I'd probably try and split the collar off then it'd be a doddle.
Mar 29, 2012 19:28:52 GMT
These are easy enough. I have done a few by splitting off the collar with a wee chisel, then hammering an impact socket onto the nut.
1986 Panda 4x4. 1990 Metro Sport. 1999 Ford Escort estate.
Mar 29, 2012 21:42:31 GMT
your local main dealer may carry a master set of keys
McGard Removal... grrrrChasR
@chasr
Club Retro Rides Member 170
Mar 29, 2012 23:28:04 GMT
When I lost my set, I went to the Ford Stealer and had them removed with a master key set. Fortunately I did find the key again, but not until years later!
johnna
Mar 30, 2012 18:05:59 GMT
Thanks everyone for your advice and best wishes.
I've another plan, but don't wish to share it just yet! Will post the outcome though.
`state
Yorkshire and The Humber
Mar 30, 2012 21:04:09 GMT
Remember to tighten the other bolts up as much as poss,might lessen the force on the locker abit to make it easier to unwind.
Look at all the plastic people who live without a care.Try to sit with me around my table,but never bring a chair.
McGard Removal... grrrrDez
@dez
Club Retro Rides Member 34
Mar 30, 2012 21:21:41 GMT
ive never met a locking wheel nut i cant remove in less than a minute with a set of impact sockets and an extension, a ratchet, and a lump hammer.
johnna
Righto, my stupid idea was to use a 'gator grip' socket I was once given by a relative for Christmas. It didn't work.
I also used a centre punch to stop the collar spinning. I banged on a 24mm socket, which split and turned.
I also damaged two chisels on the bloody thing.
I went to my local part worn tyre company and they had some old locker keys. They had a similar McGard key. Not a perfect fit, but close. Some judicious belting and turning saw all four lockers removed.
Thanks to all for their advice.
