johnd
Apr 12, 2012 20:36:19 GMT
Basicly whilst strengthening the gimp two plates have been welded together, the problem is there's bare metal in between them with no way to get paint on it... Although once sealed no water can get in..
Will this rust? Mate reckons I should've used weld through prime?
Really don't want to cut it all off?
`state
Yorkshire and The Humber
Apr 12, 2012 20:54:15 GMT
Yes yes it will rust.Moisture will find a way in and it`ll rust inside out.Id bite the bullet and sort it now i think unless its easy to get to and you can leave it til it starts to show on the outside and do it then.
Look at all the plastic people who live without a care.Try to sit with me around my table,but never bring a chair.
johnd
Apr 12, 2012 20:57:36 GMT
Probs easier to get it dipped and electro primed
luckygti
I need to try harder!
Apr 12, 2012 21:01:04 GMT
Well, I'm in the process of cutting rot out of my van and have found a piece which is suffering at a guess, from this very thing! And I can only see that cutting it all out and redoing it is the only way to banish the rust!
Mind you, my van is 33 years old, depends what sort of use the car will get and where it'll be stored? And if it's easier to do now and whether it will be a right ballache to get to down the line!
Apr 12, 2012 21:03:20 GMT
Drill a little hole and spray waxoyl/paint/used engine oil inside? Careful if you weld the hole back up again though, especially if you use waxoyl. It appears to be a little bit flammable
sparkyt
selling stuff
Apr 12, 2012 21:24:16 GMT
Aaron Ben said hole and paint just thin the paint well down
speedy88
"Nice Cortina mate"
Club RR Member Number: 118
have i dropped a boll*ckspeedy88
@speedy88
Club Retro Rides Member 118
Apr 12, 2012 21:24:48 GMT
What ben said ^^^
will
Apr 12, 2012 21:57:46 GMT
Drill a little hole and spray waxoyl/paint/used engine oil inside? Careful if you weld the hole back up again though, especially if you use waxoyl. It appears to be a little bit flammable This is what I was going to say too. Can't vouch for the long term livability of it though. You'd need to drench it with paint till your sure it's all covered than all would be fine at a guess.
Apr 12, 2012 23:17:45 GMT
Drill a hole in the top, fill it with oil, cap = profit
johnd
Think I'm going to cut the thing of grrr
I'd drill a hole and use a decent cavity wax (like Bilt Hamber) that'll stop the rust forming.
johnd
think i will do that but before hand going to use zinc prime with a wd40 type nosil to get in behind it... will wax it at a later date
Apr 14, 2012 19:48:57 GMT
weld thru primer isnt fantastic , stuff will still rust
id go with the hole and flood something in there
johnd
gong to drill holes and get it dipped/elec primed
Apr 17, 2012 12:35:18 GMT
weld thru primer isnt fantastic , stuff will still rust id go with the hole and flood something in there This is very true, as I have recently found out to my cost. Even though it does say it's galvanizing spray, it just doesn't seem strong enough. It's lasted 4 months outside though, so can't complain too loudly.
