Apr 14, 2012 17:20:22 GMT
May I pick your brains gentlemen
Car belongs to a mate, its 51 plate, 2 litre turbodiesel TDCi, manual, estate.
Its down on power, and when the engine cover is lifted theres a thick coating of carbon/soot everywhere (a good 1/2 a millimetre thick, enough to run your finger through) which seems to be originating from the turbo.
Its chucking out black smoke on accelaration
Any thoughts?
TIA
Dave
1986 BMW 628csi, 2003 Alfa Romeo 147, 1992 Jaaaaag XJ40, 1982 BMW R100 cafe racer.
Apr 14, 2012 18:01:31 GMT
Picatures may help...
Has it been messed with?
Apr 14, 2012 18:15:39 GMT
Wont see him till weds, but could get piccies then. Basically, lift the engine cover and everythings coated in soot. Thicker around the turbo area.
Car has not been messed with, and has 140k on the clock
Apr 14, 2012 18:25:11 GMT
Maybe the manifold/exhaust is leaking before it enters the turbo. that would explain the lack of power and soot under the engine cover.
Have you heard it running?
Last Edit: Apr 14, 2012 18:27:18 GMT by skinley
definitely a leaking manifold,turbo or gasket fail.
Whatever the whole lot needs stripping and cleaning as the soot contains acids which can do more harm.
check the egr, this can cause massive buildup of curse word in the intakes.
Mondeo TDCi conundrumChasR
@chasr
Club Retro Rides Member 170
Apr 15, 2012 12:17:41 GMT
It could be a leaky boost hose.
rodney
Apr 15, 2012 22:06:32 GMT
as said , egr is a common problem on turbo diesel engines , the egr and the inlet manifold etc all clog up , get it plugged in to a diagnostics as well as clean these,.
