Apr 22, 2012 14:30:37 GMT
right getting really annoyed with it now but cant afford to replace it
I think my 106 is having fueling problems as ive checked everything else
spark plugs are fine as is the cambelt and the timing
when i turn the key it tries to turn over but just wont like theres no fuel going to it
car is a 2002 1.1 tu engine
Apr 22, 2012 14:46:02 GMT
fuel pump they can give up??
1995 mk3 cavalier 1.8i 1972 1200 beetle 2010 1.2 fiat 500 "sometime's" 2000 suzuki gsxr 600 srad
Apr 22, 2012 15:39:40 GMT
will check it thanks
Apr 22, 2012 16:24:10 GMT
When you say "tries to turn over" what exactly do you mean?
If you mean that it spins over but doesn't fire at all, then fuel pump/fuel pump relay/fuel pump inertia switch would be the place to look.
If you mean tha it spins over and coughs a bit, then it's probably still a fuel issue.
If you mean that it doesn't turn at all (but perhaps just goes clunk), then you need to look at the battery and cables, starter solenoid, and starter motor.
bortaf
Apr 22, 2012 16:25:44 GMT
Trys to turn over or trys to start ? I assume you mean trys to start ? Had one in last year real bad starter, it was the temp sender for the ECU? Have you actually checked for a spark? cos could be the CPS they can give internitant problems then just totaly give up ?
Last Edit: Apr 22, 2012 16:31:29 GMT by bortaf
R.I.P photobucket
Apr 25, 2012 17:08:09 GMT
as in i turn it on with the keybut its not firing up its like it s trying to just wont I'm so bad with car mechanics think itll be a rolling shell on ebay soon
Apr 25, 2012 22:15:13 GMT
As Bortaf said I would check the resistor value on the Coolant temperature sensor first.
When a similar thing happened on my 205 it was the fuel pump relay. You could try a bodgy way of wiring it to see if the relay is to blame.
