Quick one lads,
I've got MOT tomorrow..Am I right in thinking that reverse lights are NOT tested? Or am I being thick?
Cheers Dave
bigt
Unless it was in the changes this year.....reversers are not tested for operation...no jagged edges, etc though
theres alot of new rules for MOT's now, they might have added them into it, try a google search on new mot regs.
Still no mention of reversing lamps in the manual that I can find.
when i have sat in my car for me mot he(mot man) has never said put in reverse to check the lights...... then prob bepends on what car age etc etc ..
1995 mk3 cavalier 1.8i 1972 1200 beetle 2010 1.2 fiat 500 "sometime's" 2000 suzuki gsxr 600 srad
bl1300
Reversing lamps aren't generally testable. I can think of only two occasions where they could be but neither is particularily likely.
1. If there on all the time and can't be switched off then you'd get a fail for white light showing to the rear
2. If the lenses are broken then you could be called up on sharp edges.
Both of those are non specific to reverse lights and there are no requirements specificly related to reversing lights in the manual.
Current fleet.
MOT-Reverse lightsstealthstylz
@stealthstylz
Club Retro Rides Member 174
I've never had a test failed for it. They're useful to have working though, had a number of near misses in car parks (cars and pedestrians) as people can't seem to judge a car coming towards them backwards.
Cheers lads.
^Yeah I know what you mean mate.
The reverse switch has gone everything else is intact just couldnt be arsed to get under the car to change it this morning before MOT.
Passed and like we thought, there not tested.
my work van hasnt had reverse lights for the last two tests and passed, if you reverse without them just put your hazards on and be careful as people wont notice your trying to reverse
My Caddy van had its test yesterday, and i deliberately removed the reversing bulb for test as i have red tinting film on lights, so it shines pink. Passed like that for last two years. Unless vans are different. I know commercial vehicle don't need reversing light, not sure on cars, maybe same??
May 11, 2012 19:00:23 GMT
nope not required, they don't even check to see if they're there
mikeymk
'85 Polo Coupe S 1.6 16v
May 14, 2012 21:05:16 GMT
Haven't had reverse lamps on mine for nine years now - though i've always been under the impression that it's legal if they're not there, but have to work if they are there..? Seems that's not the case, as long as a non-working one doesn't cause an issue.
May 15, 2012 16:57:07 GMT
NOT at all Required for an MOT
Dave
