Remade In Australia thereimaginarium.com.au
Nice, love the top one! Ever re-webbed an old Ercol Windsor? I've got one that needs some TLC and don't really fancy paying brand new factory prices for Ercol webbing...
Is it just a support webbing underneath the seat cushion? If you're half reasonable at playing with cars doing chair repairs (apart from upholstery, which requires atleast a basic knowledge of a sewing machine) is childs play. Take a good look at how it's attached and what it's made of, there are plenty of upholstery shops around and online which should be able to sort you out with a suitable replacement for the worn webbing
Jun 11, 2012 16:50:28 GMT
Seat belt webbing?
Jun 11, 2012 23:55:59 GMT
wheres the after pics?
Jun 12, 2012 12:44:08 GMT
You need a web stretcher to get it tight. I thing the car seat webbing is too stretchy look for one made of a hessian type of material. Essentially you double over one end tack it using upholstery tacks then use the web stretcher to pull tight the tack then double the end over and put in some more tacks.it needs criss crossing to give it a bit more support then cover from the top with a piece of cloth them put your stuufing over the top.
Ginetta G15 BMW K1100 conversion Sold Mk1 Mx5 on ITB'S Sold TVR Chimaera 400 supercharged MR2 Red Roadster 2ZZ Bee*R 324 Skyline 95 Cherokee Jeep
Jun 12, 2012 21:54:36 GMT
Jun 15, 2012 20:37:04 GMT
I play around with old chairs quite abit. These were commision pieces
Nice one! Is that a vinyl wrap or actual magazine covers? I found a couple of before pics of the denim chair:
Jun 23, 2012 19:17:22 GMT
Copied onto paper of the actual covers and then glued to the chair and built up with a lot of layers of satin clear to make sure they last well
