oohhh wow, how clean... love the look of these over the later shape one
I'm not curse word, i just fell off my shoes
retrobastard
Tits or tyres means trouble
Aug 12, 2012 13:12:43 GMT
Get a 5 speed box and linkage and earth the wire that stops you from starting in gear!! JD
Darn clean onion
Aug 12, 2012 13:26:12 GMT
Yup - that auto box on small Fords from this period were appalling! A manual box is a must!
bortaf
Aug 12, 2012 13:32:58 GMT
Get a 5 speed box and linkage and earth the wire that stops you from starting in gear!! JD Darn clean onion Yeh and change the pedal box, drill a hole in the bulkhead, weld in a mount for the clutch cable ect ect it's never as easy as people on the web/in the pub make out
R.I.P photobucket
Aug 12, 2012 13:46:56 GMT
Get a 5 speed box and linkage and earth the wire that stops you from starting in gear!! JD Darn clean onion Yeh and change the pedal box, drill a hole in the bulkhead, weld in a mount for the clutch cable ect ect it's never as easy as people on the web/in the pub make out Oh God no........it certainly wouldn't be me doing it......
retrobastard
Aug 13, 2012 18:57:03 GMT
Get a 5 speed box and linkage and earth the wire that stops you from starting in gear!! JD Darn clean onion Yeh and change the pedal box, drill a hole in the bulkhead, weld in a mount for the clutch cable ect ect it's never as easy as people on the web/in the pub make out OOoops forgot that bit! DOH! Pretty easy swap though! ;D
