www.carandclassic.co.uk/car/C327256Has a hydraulic fluid leak and apprently the replacement pipe isn't available But for £235 it must be a cheap and easy fix for someone, it has 11 months MoT and apparently a recent cambelt and tyres. I'm tempted myself, but not sure if it's driveable any distance with the leak.... Does anyone with more knowledge of BX's know the score with this? Ian
1971 Range Rover 1977 Jeep Cherokee 1982 W123 Merc 230CE 1992 Peugeot 405 TD Saloon 1995 Peugeot 405TD Estate (having a rest) 1990 Peugeot 205 CJ - For Sale 1985 Peugeot 305 GTX 1979 Honda Accord MK1 1995 BMW E34 TDS 1994 BMW E34 TD 1998 Mercedes 320 CLK
Aug 25, 2012 10:15:38 GMT
When my old BX sprang a leak i used Maplins self fusing tape until i could get the car to a garage, it held up very well. www.maplin.co.uk/silicone-self-fusing-repair-tape-227649If you DO use it though, don't chance the motorways, as the fluid controls the steering, suspension, and brakes, so if one goes, the whole lot go
stinkwheel
Doctor Of Gonzo Journalism - One of gods own proptypes, never even considered for mass production.
Aug 25, 2012 10:16:15 GMT
Its the low pressure main pump feed. Easy as anything to sort out, find a scrap xantia/XM/BX or whatever and chop out a section of pipe, some jubilee clips and metal connector tubes, job done. I'm even tempted to give him a ring now.........
1973 Citroen Dyane 6 1980 Citroen Acadiane 1992 Citroen AX 1990 Citroen BX 1997 Citroen XM 1993 Citroen BX 1997 Citroen Xantia 1977 Citroen Ami 8 1996 Ford Escort 1989 Citroen BX 1997 Suzuki RF900 1988 Yamaha TDR250 1979 Honda CB400. 'I need less vehicles'
Brian Damaged
West Midlands
Club RR Member Number: 33
Aug 25, 2012 10:39:57 GMT
That looks clean and tidy. Shame it's not a year older, in which case it'd have the original 'mad as a box of frogs' dashboard!
Aug 25, 2012 15:12:32 GMT
I'm seriously tempted, it's scrap money after all. I have e-mailed him. Not using the motorways wouldn't really be an option with me taking the car home though, even the 'A' roads on the way back would be really quite busy....
Are the pipes the same from the XM then? I just can't figure out why that type of pipe isn't available! I haven't made a fix like this before, so would be relying on getting it right first time for the drive back!
Ian
Aug 25, 2012 15:39:05 GMT
Just got an e-mail from him, he's wanting £300 including tax until end of January. He also says that he's now heard the part if available for £50 + VAT.....
Any thoughts?
Ian
Aug 25, 2012 17:07:32 GMT
DOOO EEET!!!
unsurprising if the part is not available, its an old Citroen!
eternaloptimist
Aug 25, 2012 18:17:43 GMT
Shouldn't be a safety issue - it's on the low pressure return side - if it's pouring out, eventually the reservior empties and the big STOP warning light comes on. Last thing to go is brakes.
There are probably moulded ends on the pipe that makes it specific to the BX - but if the split is in a straightish section of the pipe you can cut the pipe in half, push a short length of copper pipe in, reconnect the two halves and use a jubilee clip either side to seal the pipe.
Buy it!
Aug 25, 2012 19:02:41 GMT
Eternaloptimist, I just realised that I haven't read/replied to your PM, sorry, will do so I really don't need to read people saying 'buy it' ;D when I already really like these, have already bought a 230CE I hadn't intended on buying and am eyeing up a very cheap E30 with MoT and Tax.... On the other hand, £300 for this with 11months ticket and 5 months tax is a steal!!!! I've only ever heard the horror stories about Citroen Hydraulics, can anyone shed some light on the truth of this or not? How thirsty is the 1.9 petrol going to be? I can't really justify it if I'm not going to be able to waft about in it very much.... Thanks, Ian
Aug 26, 2012 16:04:29 GMT
Well got an e-mail today from the guy. Another chap who runs a Citroen repair centre came and bought it today! No doubt to sell it on at a huge mark-up, curse me working weekends! Earliest I'd be able to have got down was tomorrow afternoon! Still the guy was a real gent to deal with and I'll be keeping an eye out on those websites as bargains evidently still surface! Thanks everyone Ian
Phil H
Club RR Member Number: 133
Aug 30, 2012 14:51:17 GMT
90-odd% of BX fluid leaks are the Octopus pipe. Common failure as one pipe (I've done 2 of the sods) has a 180 degree bend in it which goes over time. Class them as consumable.
