Here we have a fair few things up for sale on Ebay again.
Another clear out mainly Ford Bits
All of this is listed on EBay started at 99p no reserve. I'll let the auctions dictate the values.
It's just all got to go.
everything is based in Solihull, South Birmingham.
All description and postage information is contained within each listing.
Please find the links below for each auction.
Ford Anglia Cortina Classic Zephyr Zodiac Front Wing Badge
www.ebay.co.uk/itm/130780113467?ssPageName=STRK:MESELX:IT&_trksid=p3984.m1558.l2649#ht_500wt_1156
Mk3 Ford Zephyr Zodiac Chrome Interior Door Opener Handle
www.ebay.co.uk/itm/130777496965?ssPageName=STRK:MESELX:IT&_trksid=p3984.m1558.l2649#ht_500wt_1156
Ford Zodiac Zephyr Split Exhaust Manifold
www.ebay.co.uk/itm/130775216808?ssPageName=STRK:MESELX:IT&_trksid=p3984.m1558.l2649#ht_500wt_1156
Mk3 Ford Zephyr Zodiac Aluminium Sill Trim
www.ebay.co.uk/itm/130777518817?ssPageName=STRK:MESELX:IT&_trksid=p3984.m1558.l2649#ht_500wt_1156
Ford Zephyr Zodiac Consul Pushrods
www.ebay.co.uk/itm/130780049885?ssPageName=STRK:MESELX:IT&_trksid=p3984.m1558.l2649#ht_500wt_1156
Ford Mechanical Fuel Pump (Metal Bottom) 7950416
www.ebay.co.uk/itm/130780072789?ssPageName=STRK:MESELX:IT&_trksid=p3984.m1558.l2649#ht_500wt_1156
Ford Mechanical Fuel Pump (White bottom) 7950416
www.ebay.co.uk/itm/130780075506?ssPageName=STRK:MESELX:IT&_trksid=p3984.m1558.l2649#ht_500wt_1156
Ford Mechanical Fuel Pump (With priming lever) 7950416
www.ebay.co.uk/itm/130780077878?ssPageName=STRK:MESELX:IT&_trksid=p3984.m1558.l2649#ht_500wt_1156
Ford Mechanical Glass Bowl Fuel Pump 1524151
www.ebay.co.uk/itm/130780080401?ssPageName=STRK:MESELX:IT&_trksid=p3984.m1558.l2649#ht_500wt_1156
Ford Mechanical Glass Bowl Fuel Pump 4285
www.ebay.co.uk/itm/130780082400?ssPageName=STRK:MESELX:IT&_trksid=p3984.m1558.l2649#ht_500wt_1156
Ford Mechanical Fuel Pump 152425
www.ebay.co.uk/itm/130780084371?ssPageName=STRK:MESELX:IT&_trksid=p3984.m1558.l2649#ht_500wt_1156
Ford Mk3 Zephyr 4 Mk2 Consul Water Pump (Painted)
www.ebay.co.uk/itm/130780090706?ssPageName=STRK:MESELX:IT&_trksid=p3984.m1558.l2649#ht_500wt_1156
Ford Mk3 Zephyr 4 Mk2 Consul Water Pump (Surface rust)
www.ebay.co.uk/itm/130780092664?ssPageName=STRK:MESELX:IT&_trksid=p3984.m1558.l2649#ht_500wt_1156
Mk3 Ford Zephyr Zodiac Steering Wheel Badge Surround
www.ebay.co.uk/itm/130780102496?ssPageName=STRK:MESELX:IT&_trksid=p3984.m1558.l2649#ht_500wt_1156
Mk3 Ford Zephyr Zodiac Rear Light Assembly Trim
www.ebay.co.uk/itm/130780118051?ssPageName=STRK:MESELX:IT&_trksid=p3984.m1558.l2649#ht_500wt_1156
Ford Overdrive Badge
www.ebay.co.uk/itm/130780123455?ssPageName=STRK:MESELX:IT&_trksid=p3984.m1558.l2649#ht_500wt_1156
Mk3 Ford Zephyr Zodiac Chrome Interior Door Opener Handles
www.ebay.co.uk/itm/130777498711?ssPageName=STRK:MESELX:IT&_trksid=p3984.m1558.l2649#ht_500wt_1156
Ford Zephyr Zodiac Consul Girling Brake Master Cylinder CC2 13/16
www.ebay.co.uk/itm/130780009283?ssPageName=STRK:MESELX:IT&_trksid=p3984.m1558.l2649#ht_500wt_1156
(No Cap) www.ebay.co.uk/itm/130780013214?ssPageName=STRK:MESELX:IT&_trksid=p3984.m1558.l2649#ht_500wt_1156
Ford Zephyr Zodiac Consul Girling Clutch Master Cylinder CC1 75
www.ebay.co.uk/itm/130780021862?ssPageName=STRK:MESELX:IT&_trksid=p3984.m1558.l2649#ht_500wt_1156
Mk2 Ford Consul Gearbox Flywheel Dustcover
www.ebay.co.uk/itm/130780057388?ssPageName=STRK:MESELX:IT&_trksid=p3984.m1558.l2649#ht_500wt_1156
Mk3 Ford Zephyr 4 Gearbox Flywheel Dustcover
www.ebay.co.uk/itm/130780061424?ssPageName=STRK:MESELX:IT&_trksid=p3984.m1558.l2649#ht_500wt_1156
Ford Zephyr Zodiac Consul Track Control Arm TCA
www.ebay.co.uk/itm/130780066410?ssPageName=STRK:MESELX:IT&_trksid=p3984.m1558.l2649#ht_500wt_1156
Lucas Mk3 Zephyr Zodiac Voltage Regulator
www.ebay.co.uk/itm/130780098636?ssPageName=STRK:MESELX:IT&_trksid=p3984.m1558.l2649#ht_500wt_1156
Lucas C42 22900 Dynamo Ford Zephyr Zodiac Consul
www.ebay.co.uk/itm/130780110538?ssPageName=STRK:MESELX:IT&_trksid=p3984.m1558.l2649#ht_500wt_1156
Mk3 Ford Zephyr Zodiac Window Trim
www.ebay.co.uk/itm/130780122172?ssPageName=STRK:MESELX:IT&_trksid=p3984.m1558.l2649#ht_500wt_1156
Girling Master Cylinder Reservoir Extension
www.ebay.co.uk/itm/130780043628?ssPageName=STRK:MESELX:IT&_trksid=p3984.m1558.l2649#ht_500wt_1156
Lucas B90 Dynamo Ford Zephyr Zodiac Consul
www.ebay.co.uk/itm/130780107867?ssPageName=STRK:MESELX:IT&_trksid=p3984.m1558.l2649#ht_500wt_1156
Ford Zodiac Spare Bonnet Letters
www.ebay.co.uk/itm/130780126062?ssPageName=STRK:MESELX:IT&_trksid=p3984.m1558.l2649#ht_500wt_1156
Ford Mk3 Zephyr Zodiac Red Rear Light Lens Cover
www.ebay.co.uk/itm/130775238660?ssPageName=STRK:MESELX:IT&_trksid=p3984.m1558.l2649#ht_500wt_1156
Ford Zephyr Zodiac Zenith Carburettor 42 WIA 2 C1776
www.ebay.co.uk/itm/130775235414?ssPageName=STRK:MESELX:IT&_trksid=p3984.m1558.l2649#ht_500wt_1156
Lucas Headlamp Bowls Ford MG Austin Healey Jaguar Land Rover Triumph Morris
www.ebay.co.uk/itm/130775231738?ssPageName=STRK:MESELX:IT&_trksid=p3984.m1558.l2649#ht_500wt_1156
