tigran
In rust we trust. Amen.
Club RR Member Number: 142
Me and a buddy have (provisionally) bought a saab 900 turbo with a borked gearbox (only 4th and 5th left). Hunting about for a new gearbox now so want to ask what was saab's part sharing back then? Would the gearbox from a 1988 900 tubby be the same as that from an '89 saab 9000 2.3 and so on. Also did they make these in 3 door saloon form? Just the end on this un looks different. Thanks for any help. To keep it vaguely car related:
80mojo
Yes they did do a 3-door hatch 900. The red one above is one. Can't help with the gearbox question, but have a look on www.uksaabs.co.uk
Last Edit: Jan 2, 2007 17:47:43 GMT by 80mojo
'71 Opel GT '72 Manta A '79 Dodge Autosleeper '83 Monza & a half '86 Manta GT/E V6 '91 Astra SXi '94 Carlton Diamond Estate 24v
:)I'm not a Saab expert but I do know the original 900 gearbox is totally different to a 9000. The 900 box is under the engine, bit similar to a Mini, while the 9000 has a more traditional side mounted box.
tigran
No G I know they did a 3 door just never knew they did a 2 door as ross' appears to be. It confused the hell out of me for a while as something just didn't look right. Kinda gowing on me though (luckily).
bobz
The gearboxes are nout like in a 9000, like daverapid, they're mounted under the engine- but at the nose end. A bit like an old DS or CX It's really not worth just fitting a second hand box tho, as they are all (5 speeders anyway) inherently week. So ideally you'd want to take it to a gearbox re-builder to look over it first. If it's been taken out of another car, it's most likely fook't already, so you'd probably just repairing the one that's in the car.................trust me
Don't plan anything, it'll start raining!
bobz
Last Edit: Jan 2, 2007 19:52:09 GMT by bobz
slammed 66
www.gtturbo.org
Hey Tigran, there were less than 200 2 door t16s' imported into this country making it a rare bear indeed! Any 900 gearbox will fit, turbo or not. The chain from the knackered box and primaries will want swapping into the new box, thats all. Theres a full guide on the uksaabs forum
86 Renault 5 GT Turbo 89 Renault extra 91 Skyline GTR 98 Mini 1275 mpi 99 Autech Rider www.gtturbo.org
OK, the engine in a proper 900 in that one is mounted north/south like most RWD cars, even though it is FWD. It si so they could equal length driveshafts. The engine sits ontop of the box, and load is transfered via a multi row chain. Rather than mess with the final drive you can change things by altering the primary chain drive. I believe No6 is for non turbos and fitted to a turbo you will have massive acceleration but no top end before the rev limiter slams your face into the windscreen. Number 7 is for normal early turbos. Number 8 primary drive gear set is prized as it was only used on certain early models and Some of the latest ones. It gives the best pull and top end combination to allow you masx out the torque the engine can put out when tuned. The top of the transmission case is the oil pan for the engine. Later transmissions are the ones to have. Normally it is an engine out job to change, but some of the specialists have a technique. that can do it but just lifting it and lowering a cross member. if you have it out, do all the wishbone bushes. LHS lower (I think, but one of them anyway) shares with the engine mount so you need to lift the engine to change the bush anyway and they get covered in oil as they are right under the dipstick, where the oil spills when you change the filter and where the oil cooler lines spray when they split and the airstream carries it. There is some adjustment and alignment you can do if you think the box might have some life in it. www.saabcentral.comwww.saabscene.comwww.uksaabs.net all have forums worth joining. Drive shafts changed at the box end as the boxes were improved, so get the shafts if it is from a different year car (one of the specialists will know if you need them). Later boxes didn't have a drain plug or dipstick/filler, but the dipstick could be refitted. To drain them you removed the end cover off the diff, and cleaned the filter while you were there. Early models had a drainplug and you filled it through the dipstick. Later models where filled from a nut type filler plug. The boxes are the weakspot on the C900. Eriksson's do the best custom boxes (not Eriksson industries, they just do refurbed boxes). The ultimate boxes are apparently 4 speed, with chill cast casings and hardened internals with No8 primaries.
No G I know they did a 3 door just never knew they did a 2 door as ross' appears to be. It confused the hell out of me for a while as something just didn't look right. Kinda gowing on me though (luckily). There were 3 and 5 door hatches and 2 and 4 door saloon 900 models. Very few 900 T16S models made in 2 door, but the T8 race series used 2 door shells. They are the stiffest shell to use. And the 2 door is the base for the convertible. BTW, the black one above is a 99 (not a flake in site, Boom, Boom).
bobz
They also did a LWB model in the early days. (badged CD I think) And the 2 door one is the stiffest shell.
tigran
Whoa, thanks for the mass help peeps. Looks like a 2 door is the ideal shell to make a track warrior from then.
Kewl!
Yup. It certainly is. And Bobz, yes there was the long wheel base CD model. It was the Corps Diplomatic, so embassy people as well as celebrities had that little bit more room than mere commoners..
Oi, leave the chillcasts for people with 99's They're hard enough to find as it is ;D
Sorry, just trying to spread the wealth
