task
I also have to admit to failing. I have bought rivet on archs. Due to widening the front track 45mm either side, I now require wider than originally planned archs, and due to time constraints (rather spend time on fitting the new engine rather than curse word about with the bodywork) ive decided to just cheat and whack a set of rivet on archs on it. Nice, I like the B and good to see it being used I'm looking forward to photos of the arches fitted, I want to add flared arches during my MGB restoration/modification but I'm not really feeling the sebring arches.
No work on the MGB this weekend but thought some people may like to see this. Got asked to make a manifold for my mates MX5 (the one I did the clutch on a few weeks ago) and stupidly said yeah why not. Turned these - Into this - And then nearly finished the downpipe - Still got loads to do on it before its off the drive but I'm still pulling the engine out the MGB next weekend to make way for the new lump.
'69 MG Midget | '94 200SX S13 RB25DET Project
mk2cossie
Club RR Member Number: 77
1980 MGB - Project: Driftmk2cossie
@mk2cossie
Club Retro Rides Member 77
nice fab work with the tubby manifold there ;D But...the flange is in the wrong place and will cause hot spots for the other 3 cylinders as cylinder 2 is the only direct feed to the turbo Any pics of the arches on the B yet? ;D
Last Edit: Dec 9, 2012 20:49:40 GMT by mk2cossie
nice fab work with the tubby manifold there ;D But...the flange is in the wrong place and will cause hot spots for the other 3 cylinders as cylinder 2 is the only direct feed to the turbo Any pics of the arches on the B yet? ;D Aye, I raised these issues with him but was told to shut up and just make it He was going off of images of all the other home made MX5 turbo manifolds out there and they are all the same (very limited space to actually build a proper mani and he only gave me a 180 degree bend to work with ) and when running a T25 you need to have it over cyl 2 to have space to make the downpipe Archs still havent turned up Loads of other stuff has but havent had the time to do anything with it! If they arrive next weekend i'll try and get them on
Dec 10, 2012 14:21:20 GMT
it was cold watching you make that manifold man. bloody cold. haha
Dec 10, 2012 18:56:25 GMT
it was cold watching you make that manifold man. bloody cold. haha haha, cheers for the company mannnnnn and yeah, hopefully most the work from now on can be done with the door shut lol
Dec 17, 2012 22:58:58 GMT
Well, not much done to the MGB again, but the MX5 is done... and its a proper laugh. But, I did throw one of my rivet on arch's on And bought a hydro - And also drained the fuel out of it ready to drop it for ally race cell. hopefully pull the engine out next saturday and get the new lump in situ for measurements
Dec 18, 2012 11:48:26 GMT
what are you doing for front indicators, out of interest? Don't you need them to remain road legal? Looking good tho, nice to be different!
Last Edit: Dec 18, 2012 11:50:08 GMT by chodjinn
Dec 18, 2012 12:22:15 GMT
they're tucked behind the chrome. just by the red wire in the last pic
Dec 19, 2012 17:19:14 GMT
Aye, as alex said, got a set of early indicators but having welded the wings up I don't really want to put them back on...
Dec 23, 2012 17:46:04 GMT
Borrowed quite possibly one of the sexiest wheels off a mate... Regret it instantly, because they look absolutely nuts, and now I need to buy them.
Mike
East Midlands
Dec 23, 2012 18:11:55 GMT
1980 MGB - Project: DriftChasR
@chasr
Club Retro Rides Member 170
Dec 23, 2012 19:24:07 GMT
I have to say that the Rotas looked spot on that car . It is certainly a great way to go about styling an MGB. Only thing I wish to ask is, regarding the rear arch section, what do you plan to do about replacing the strength of the inner and outer arches once they are removed for the addition of JDM arches?
Dec 23, 2012 19:26:20 GMT
Making new tubs as the current ones are janky, and seeing as the final intention is 4 link w/ coilovers, need to have decent tubs, and they will be welded to the outer arch.
Dec 30, 2012 19:20:07 GMT
Finally got somewhere today, pulled the engine out - At start of play Halfway there - Oh yeah - I remember a definition "Engine Crane - A mechanical device used to test the strength of ones speedo cable" Oops - Empty bay!
Got the CA block bolted up to the gearbox and did some comparisons, looks like it'll fit beautifully, gearbox is far narrower and the shifter only sits about an inch further back with the engine sat in the "stock" location
Nov 24, 2013 19:02:41 GMT
Hows this coming on mate?
Nobody dies a virgin, because lifes curse word us ALL
Siert
Nov 24, 2013 19:17:29 GMT
I remember a definition "Engine Crane - A mechanical device used to test the strength of ones speedo cable" Lol, that does sound familiar indeed
Nov 25, 2013 19:11:00 GMT
Hows this coming on mate? Well, I got the CA in, and was measuring for prop length and jacked the back up to double check, rear spring hangers twisted and one ripped out the shell from the crash damage, found a load of hidden rot that was hiding and decided to call it a day for this shell. Its unfortunatly been stripped and scrapped, going to look for another MGB in the future to do it properly but this shell wasnt worth spending any more time on Ideally want to start with a heritage shell and put full s-body running gear under it to get proper suspension but until I get a unit sorted (and the skyline engine in the S13) then its on a backburner.
epiko
Hey any progress on this build? I'm real interested in doing something like this on my gt, especially those arches!
