tigran
In rust we trust. Amen.
Club RR Member Number: 142
Jan 12, 2007 19:42:32 GMT
Found a replacement pinto for the crapi instead of bothering rebuilding the basket case bottom end on mine. However this engine has come off a manual - mine's an auto. How do the two differ - does the auto have a flywheel - is my main question.
Want to know this before I get the gerabox and engine seperated on sunday.
Thanks.
Jan 12, 2007 20:17:34 GMT
The manual engine has a thick heavy flywheel, the auto has a thin steel flexplate that the torque converter bolts to. Both are interchangeable but before you try and force the two together check the spigot bearing in the end of the crank is the same diameter on both. 99% of the time it is but there are two sizes on Ford engines just to prewarn you.
Jan 12, 2007 20:42:49 GMT
another thing, tigran. the manual will have a spigot bush in the end of the crank, your auto won't have, but it may or may not have a shim of sorts to take the nose of the torque convertor ![:)](//storage.proboards.com/forum/images/smiley/smiley.png)
tigran
Jan 12, 2007 23:36:03 GMT
Why is nothing ever simple with retros.
*swears to chuck the C3 in the bin soon as he gets back to bournemouth*
Well it should be entertaining anyway. Thanks for the help peeps.
Last Edit: Jan 12, 2007 23:38:22 GMT by tigran
