Shortcut
I won't be there when you cross the road, so always use the Green Cross Code.
Oct 12, 2004 14:56:23 GMT
I've got two new wider wheels for the back of the ZS but they is grey and they need to be white. is it best to send them off to be painted or can I safely bodge it at home and if so how.
In the same vein I have some bigger veted front diss and calipers and I'd quite like to paint the calipers blue to match the car. i guess this I CAN do but I will need heat resistant paint?
This space available to rent. Reach literally dozens of people. Cheap rates!
How do I...DarrenW
@darrenw
Club Retro Rides Member 74
Oct 12, 2004 14:59:16 GMT
You can use smoothrite to paint the wheels - my old Mini had wellers that I painted white with the stuff, no problems
Oct 12, 2004 15:00:47 GMT
How about some kind of glue you can spray on (spray mount?) then spray-paint over the top of, as it will give a key to the surface of the wheel without having to sand them at all, thus not damaging the faces?
It's just a guess though.....
For calipers, heat resistant is preferable. See you local Ned accessory shop: they'll have some in stock.
Oct 12, 2004 15:04:49 GMT
if theres no rust on them just scotch pad them and primer and paint
me dad repainted his 4x4 alloys and 3 were scabby but one was fine roughed it up primered and painted its fine
2001 HONDA CT110 (NOT RCV)
Oct 12, 2004 15:05:27 GMT
How do I...BenzBoy
@benzboy
Oct 12, 2004 20:06:32 GMT
Yeah I painted my alloys by just keying up the old paint, getting rid of the flaky chunks, then priming and painting with regular car spray paint. Bosh a little lacquer over it and hey presto. That said, the pro's do a proper job with sandblasting and all - I intend to get it done to my alloys when I can afford it, and to take out the huge scuffs that the rims have suffered by having low profiles on them!
SkoCan
Quando omni flunkus, mortati
Oct 12, 2004 21:28:56 GMT
Do you folks have Tremclad over there? Years ago I painted some new black wheels for the Tercel in silver. Tremclad is selfpriming in this case. Just wiped them down and hit them with 2-3 coats. Lasted for about four years, winter and summer, before it started to fade.
If you paint your callipers with regular paint itll last one day. Use heat resistant if you want it to last
Make sure its totally dry as well, if its only just try and you drive on it itll get coated in brake dust which will never clean off
