andyborris
Sept 29, 2013 16:50:43 GMT
Long shot I know on a car based forum ! I have to build a pontoon/raft to carry around 6 tonne, so looking for someone with boat design experience to check my design/maths.....? Sorry if you've already seen this question on another forum. Thanks Andy
omega
Sept 29, 2013 16:57:53 GMT
pointy end to the front.
Sept 29, 2013 17:19:51 GMT
Ones with big bits of material need wind.
Toyota mk3 supra. retro goodness.
andyborris
Sept 29, 2013 17:54:34 GMT
All good advice.....
Sept 29, 2013 20:12:12 GMT
Used to work for a yacht design company (there for 10 1/2 years) - pm me to discuss in more detail what you want to know.
Last Edit: Sept 29, 2013 20:13:26 GMT by Paul H
jonw
Can open a Mouse with a File
Sept 30, 2013 7:06:13 GMT
Other than you have to displace greater than 6 tonnes of water to float (some greek guy discovered this in his bath.... strange person....) I'm in the dark.
My guess would be though, that you need the centre of gravity nice and low, probably near the water line to make the thing as stable as possible. You'd also want it wide and flat bottomed for the same reason. The only issue I can see will be drag. I'd guess this is proportional to the frontal area, so a wide single hull will be a big drag, and the submerged surface area. Also a short wide craft may struggle to go straight so directional stability will dictate a long thin craft.
I'm not sure if this helps...
Suzuki SV650R The good Triumph T20 The Bad BMW G650GS The Ugly Matchless G12CSR The Smokey Toyota Hybrid One pint or Two?
Ingredients of this post Spam Drunken Rambling of author Bad spelling Drunken ramblings of inner voices Occasional pointless comments Vile beef trimming they won't even use in stock cubes
