Loads more picture available on request, also on eBay.
2000 'X' BMW 318i SE
Beautiful Topaz Blue
138k
PAS
ABS
Remote Central Locking
12 Months MOT
Air-Con
Climate Control
E/W x 4
E/M
6 CD Changer
Auto-Dimming Rear Mirror
Switchable Traction Control
Front Fog Lights
4 Virtually New Tyres
Rear Parking Sensors
Full MOT History Print Out
6K since last MOT
Full HPI Report
The car is missing it's service book but this engine is a CHAIN driven engine so no timing belt to worry about. don't fear though as there is a huge stack of receipts from over the years, these are as follows:
10.06.04 - GSF Car Parts. Oil,Air,Fuel and Pollen Filters, Oil, Spark Plugs x4.
17.06.04 - Peter Michaels BMW Specialist. Diagnostics - Faulty Breather Valve.
20.08.04 - BMW Parts. Air Flow Meter.
09.06.05 - GSF Car Parts. Oil and Oil Filter.
09.11.05 - GSF Car Parts. Lower Track Control Arm (R/H) & Track Rod End
09.11.05 - Peter Michaels BMW Specialist. Thermostat.
26.07.06 - GSF Car Parts. Oil, Oil Filter, Spark Plugs x4.
25.08.07 - GSF Car Parts. Anti-Freeze, Oil Filter.
28.11.07 - BMW. Connector.
17.11.07 - Motor Clinic. Battery.
02.06.08 - Peter Michaels BMW Specialist. Anti-Freeze, Water Pump.
03.06.08 - GSF Car Parts. Handbrake Shoes.
09.06.08 - Derby Motor Spares. Rear Brake Disc, Pad and Handbrake Shoes.
14.07.08 - GSF Car Parts. Brake Pad Set.
07.10.08 - GSF Car Parts. Oil Filter, Front Track Control Arm Bush (R/H).
08.10.08 - GSF Car Parts. Anti Roll Bar Link.
17.10.08 - GSF Car Parts. Front Track Control Arm Lower (R/H).
10.12.08 - BMW. O' Ring.
10.12.08 - BMW. Gasket.
11.12.08 - GSF Car Parts. Ribbed Belt x2.
23.12.08 - BMW. Bolt x2.
17.02.09 - GSF Car Parts. Front Pads.
13.01.09 - Cars 4 Less. NSF Suspension Arm.
29.05.09 - Cars 4 Less. Lamda Sensor.
On viewing the car since i have had it i can see it has had the following work carried out on it recently:
Recent Exhaust - Middle to including back box
Recent Rear Shock Absorbers
Recent Brake Pad Sensors - Front and Rear
Recent ABS Sensor
The car is in very good condition for its age, its not the usual rusty BMW e46 of this age with rusty wheel arches on the front and rear or oil leaks in the engine bay. It does have the odd age related mark here and there but the only ones worth mentioning are the ones i have pictured:
A little scuff near the rear passenger side wheel arch on the side skirt (These only clip on if you find one in the same colour.) with a minor bit of rust on the inside of the wheel arch lip itself (would tidy up massively with a bit of polish, but i'd rather you see the car worts and all)
Minor rust Scab under the bootlid between that and the rear bumper (Hardly noticeable had i not mentioned it)
I've done 2.5k since May in it and had no issues what so ever, the only reason i'm selling it is because i have bought a 320 estate.
I'm not a trader and as such i will be selling the vehicle on a 'Sold as Seen' basis. The car has just gone through a MOT so will provide you with 12 months easy motoring.
Any inspection/viewing welcomed.
Vehicle is located in Sleaford ng34 7ql
