Jan 12, 2015 20:11:36 GMT
Well. gtt parts wont really help me, but i always keep my eye out.
With the peugeot aswell ive got a set of spares for both cars and then another set for the 5, also this bloody monster I'm still trying to get rid of.
Jan 12, 2015 20:16:42 GMT
If I ever get everything here organised and come across it I'll let you know, I know the turbo is gone but everything else should still be there and you could have it for free/swap for the wheels if you want.
I need to do this/a similar swap in my 5 still, yours is probably running at least 3-4 times the amount of power mine does haha.
Jan 12, 2015 20:25:34 GMT
Have you got a spare engine? When it was in the volvo it was supposed to be getting 170hp, but now its in a lighter shell, quicker gearbox and boost keeps creeping up to 25 psi, i rekon it flys up to something like 200. I want more though
Jan 12, 2015 20:32:01 GMT
The Williams is too nice to take the engine from so I'd probably take Lake's offer on a 440/60/80 turbo. I've just about got enough £ for it but I'll probably need to daily the '76 so I can keep the 5 off the road to do the swap. (how long did yours take?)
Jan 12, 2015 22:21:08 GMT
Took me around 3 weeks to finalise it. But I had another car to use. Tbh I think I could do another in a weekend.
Jan 12, 2015 23:24:22 GMT
I can get it mated to the 'box and dropped in when I buy it, then finish it back here but I think it's the wiring that scares me the most haha
Jan 13, 2015 13:47:14 GMT
Wiring was only 12v to ecu. And ignition. I think
Jan 13, 2015 13:48:02 GMT
The hardest bit foe me was the cooling arangement
Jan 13, 2015 21:04:43 GMT
Ok, rocker cover and inlet paint time. Coat 1 Blue for inlet fanimold and yellow for the cover (means i can compliment the wheels with either) The suspect oil feed pipe Nothing wrong with that, so the oil leak is not from there, which means i don't have to get a braided hose, so thats good. Next theory is the drain, or just a dodgy sump or sump plug. They have both had a fair few whacks. Id like a bracket for the boost controller, will have to knock something up at work. Turbo has been blowing, so have to order a new gasket. I'm pretty sure ive been through about 4 of these now and 3 of the fibre ones. I think ill get a fibre one but give the housing and manifold a file first. Will have to get a second coat on the paint parts when i get a chance. Get all that back on, then have a good look at the cooling setup. Ive decided against a front mount aswell.
Jan 13, 2015 21:07:26 GMT
As i was flashing through my photobucket the next photo that came up was one of my unfinished projects Was sold then broken for spares
Jan 22, 2015 19:06:13 GMT
I'm getting half hour here, half hour there. Ive filed the turbo and manifold ports down and put the gasket back in and bolted that up nice and tight (see if that leaks again, I'm betting it will) Re-routed some of the earths and the loom round the turret as it was getting a battering from the cam belt cover and p-cliped that down. The rocker covers back on. The manifolds back on. Got some of these GTT shocks to pick up. Think they're koni. Meaning I can get my GTT hubs on and have some performance suspension and brakes. While I'm at that ill put new bottom ball joints on as they were an advisory last mot. Next on the list is: Make up a throttle gasket as i broke the old one. Cut the fuel lines down to a sensible size and tie back. Cut the brake servo line down about 30mm so its not stressing itself. Tidy up the fan and temp wiring. Source a nice catch tank (probably get a GTT or clio one) and make up a bracket for it or put it in the scuttle with the ECU's Make up ECU and boost controller brackets. Then get it rolling and wait for summer to mess with wheels and stuff.
Jan 22, 2015 19:08:37 GMT
And a bonus picture of my finger
jonxs
Jan 22, 2015 19:51:40 GMT
Looks good mate. What you do to your finger??
Jan 22, 2015 20:23:59 GMT
I cut it opening the holes on the p clip haha. Then the glove made it look like I've dipped it in paint
Jan 22, 2015 20:41:15 GMT
Looking good as always! That Volvo lump is cool as
skrapz
Jan 23, 2015 10:18:31 GMT
This looks hard as nails with those wheels.
I'd rather loose by a mile cause I built my own car than win by an inch because someone else built it for me. Your car is your story, so don't let anyone else write the book.
Clio mk2
Jan 23, 2015 12:03:59 GMT
Cheers, I loved it but they just did not fit and I didn't want to modify anything to get them to fit.
Jan 25, 2015 17:20:07 GMT
Ive put it all back together and now it wont start. Brilliant.
Jan 26, 2015 20:34:25 GMT
Yeah it wont work. I have power to the ignition relay and power going out of it to the fuel pump relay. But fuel pump is doing nothing, i have no fuel and no spark. But it is cranking. Anyone have any ideas on what to check next? Mark
jonxs
Is your fuel pump fudged? Does it work when its wired straight to battery?
