vulgalour
Club RR Member Number: 146
Sept 14, 2016 18:43:49 GMT
I have thought about giving it a try and it scares me as a job. Which, the more I think about it, is a daft statement really. I've been quite ambitious with other things and they've gone okay, I just get very nervous about mechanical jobs. This is very silly of me since I've successfully done other mechanical things and I've certainly had more successful spannering jobs than failures.
The biggest obstacle is that I don't have a long-term plan with this car. I don't know if I want it running and punted on or kept as a knockabout toy. I know where I am with the other two and where I want to be, the Renault I'm not so sure on. It's probably that uncertainty that's making me hesitate.
I'm feeling like I don't know if I want to stick it out or not right at the point the project is so close to being done. It's that awkward spot when a lot of projects pop up for sale on eBay, isn't it? I'm falling into that trap. Uncertainty and self-doubt of what to do for the best.
SO... we measure things when there's time and we figure out what's wrong and reassess the options. Does that sound good? I'm hoping to head over to the unit later tonight and get some measurements made.
Paul Y
Sept 14, 2016 19:07:44 GMT
You have already proved that you can instal and remove an engine. Therefore you can instal a R5 Engine. Now, I must admit to spending way too much time researching this but, from what I can gather the only fabrication needed (if keeping the original gearbox) is possibly enlarging the slot in the bellhousing to enable the fan belt to be removed easily. SLightly more complicated if you go with the gearbox but, for somebody that has carried out the rust repair and fabrication on the Princess nothing that you can't cope with. Again, look at the link I shared earlier where the guy put an R5 Gordini engine and box in his R4. Not twisting your arm on this but it would just seem that taking a running engine out of a 5 and putting it in your 6 would provide instant (well near instant) gratification in the driving whilst fettling rather than the not driving whilst fettling category. However, it is your car. I like it either way but then if it was mine I would have had a R5T engine in there (mid mounted) and a 7 year project.... Here if you need some assistance. Now enough procrastination man! P.
Sept 14, 2016 20:45:00 GMT
Go on, put a V8 in it, you know you want to
vulgalour
Sept 17, 2016 18:40:52 GMT
Renault newsBrief though it is. I've been a bit of a noob and have half the parts of the engine at home and half at the unit, so I can't measure the journals. Spesh, I know. What I have been able to do is measure the crankshaft with the micrometers and found that all the bits that run against the bearings are all uniform with no sign of ovalling or distortion. I hope that means I can avoid a crankshaft regrind. I've also found that the problem journal/bearing in the engine is the same one that had a stuck piston when I dismantled it, so that's probably related to the HGF etc. I've come to the conclusion that I'm not going to plan any engine, stock or otherwise, until I've learned how to investigate this one. If I can understand what went wrong and what's needed I'm in a better place to resolve that. I just need to get all the bits and all the tools in the same place... which I managed to forget to do today and only realised after I'd done the 4 mile drive to the unit. Princess newsI've ordered a compression fitting for the pipe to replace the bodge and very suddenly found that the car now needs to be put outside again. I don't have enough time to finish off all the filler before the paint goes on, which is very annoying. In protest, the pipe bodge has started to leak and now the car can't easily be moved because it's resting its arches on its tyres. Not to worry, I did what I could with the filler on the car to make it look as presentable as I could in the time I had and then used the paint I do have to get a weather proof coating on the primer and bare metal areas before it does go outside. This is not the way I wanted to do things, it's the way it has to be. I'd rather a quick bodge-paint now to flash rust and bigger problems later. It means I'll likely only be able to bring the car in for a single day to get work done or work outdoors which is not an ideal situation but one I've worked in before. Photographs quite well, all the same. The filler work that's left to do is the final fettling, the bit that takes ages to get right. The bulk of it is done. It's not too shabby from a few feet away. I'll reinstall the rear lights tomorrow most likely when the paint has hardened a bit. To be honest, you can't really see the bad bits that much in the photographs and the purple is surprisingly flattering when it comes to imperfections. I'm likely switching to the Rustoleum beige in favour of the Halfords paint because it's a nicer, brighter shade that compliments the purple and it's cheaper. It's also nicer to work with and gives a smoother finish straight out the tin.
Last Edit: Sept 17, 2016 18:42:02 GMT by vulgalour
Sept 17, 2016 20:36:24 GMT
Shame if you put the wing mirrors back on - the front end looks pretty sharp now.
For the renault crank - most machine shops will check the crank & rods for very little money and tell you exactly if they are ok or no good.
Sept 17, 2016 20:59:02 GMT
This R4 engine is bugging me now, I'd like to get to the bottom of it! Let me see if I've got this straight:
So if you rebuilt it without putting the big end cap on number x cylinder it should all turn nicely when torqued down correctly.
Put big end cap on cylinder x and it's too tight to turn when torqued down but loosend off by 10lbfts and it's fine?
If so there must be an issue with either the rod, big end cap or shells on that cylinder
It must have been running when it stopped so we should be able to rule out things like someone filing a bit off the bearing cap to tighten up the tolerances. It obviously wasn't tight when in use or the bearing would have been down to the copper and the crank would show it. Could it possibly have distorted the shell when they spun?
The Princess I think is looking quite well, got to admit I wasn't taken with the rear lights when you started but now it's done I must congratulate you on your vision . Said it before but I do like that purple colour.
Last Edit: Sept 17, 2016 21:05:26 GMT by dodgerover
Sept 17, 2016 22:22:56 GMT
Is it possible it has hydrauliced or even tried to be tow started with the seized pison and the rod is bent or twisted? If you get some plastigauge you should be able to see if is clamping on one side more than the other.
vulgalour
Sept 17, 2016 23:47:44 GMT
Renault
I tried swapping the big end caps to see if it changed which one binds and it makes no difference, it's always the same one which, if memory serves, is also the piston that was most stuck. A bent rod could be the culprit. There's no sign of machining work on the bearings and the one that span on first reassembly isn't the one that's affected. In fact, if you move that cap between the rods, it only binds on the one suspect which leads me to believe it is related directly to that one and not the bearing itself. I've got a micrometer for measuring the journals, if I remember and have time tomorrow I intend to get that done.
Princess
Those wing mirrors are not going back on, I have decided. Just trying to do the suspension with them fitted, and general fettling, is so awkward. I just need to get the door mirror plinths made up and send a template off to a friend down in Bristol who has offered to make me a pair in nice shiny metal in exchange for some work I did for him earlier this year. The door mirrors will offer more rear visibility and keep the front end looking smooth and uncluttered, I hope.
There might be a delay in any progress. The Princess being booted out of the unit may be quickly followed by a demand that the Renault also be put out of sight (kind of tricky with no engine, gearbox or steering rack). I'm used to this now, it happens a lot. I work hard to earn the use of the unit in my free time, carefully agree on what work I can do over what timescale and then, before the time is close to up, I got told to pack everything up and move whatever I'm working on. This normally happens when a car is in bare metal or can't be moved, so I have to bolt the whole thing together and hastily get some weatherproofing on it so it sits outside for a couple of months before I'm allowed back in.
It wears a bit thin. If I don't help out at the unit then I won't have access to the space and tools I need at the moment and while I started out wanted to help out even without this reward, now I feel like it's not working out for me and that the work I'm putting in is being taken advantage of. Recently, the same root cause of this problem (not Mike, I hasten to add, he's just as frustrated by this as I am) decided to tell a potential customer that I'd weld up his Sunbeam no problem without even asking me. You can't do that. I feel like I'm being taken for a bit of a ride just lately and when I'm this close to having both cars sorted one way or another, the frustration is magnified.
I would have liked (and had been promised) use of the unit to do the cambelt on the Rover recently. The reason that was done at home on the driveway was to avoid the ballache that is the unit right now. Realistically, I want to walk away from it. Unfortunately I have too much riding on it right now so I have to keep things sweet at my own expense. I'll be happy when I can just drive my cars.
Last Edit: Sept 17, 2016 23:49:03 GMT by vulgalour
Sept 18, 2016 0:22:39 GMT
Well you've done exactly what I was going to suggest which has narrowed it down. I've never seen a rod bend sideways when hydrolicd though they've always bent in the direction/ plane of rotation. Fingers crossed the plastigauge shows something.
Sept 18, 2016 13:14:46 GMT
Now its got some purple on there its really starting to look rather cool, and with those lotus wheels its going to have a really good look when its finnished. As said, youve got a good vision and i think i can see where your heading with it. I like it.
Sept 18, 2016 16:54:43 GMT
Have you made enquiries on Clementine's forum? www.renault4.co.uk/ As the engine is compatible, and someone might have further info, (or a spare engine)
74 Mk1 Escort 1360, 1971 Vauxhall Victor SL2000 Estate.
vulgalour
Sept 18, 2016 17:16:22 GMT
accord83 : I've got a copy of the Renault bits of this thread on there, really early on I was offered an engine but didn't have the cash to go for it, the logistics were a bit of a nightmare and I wanted to find out what was wrong with this one. I should have tried harder to buy it I suppose, the car would be running by now if I had. The Renault is going to be coming back to the house now that Mike has managed to get in touch with the guy that usually transports cars for him. All I need to do is get the steering rack and ball joints refitted on the Renault so it can roll and steer and give the transporter guy 48 hours notice. It'll cost me about £20, all being well. I'll bring the engine home in the back of the Renault at the same time, put the car in the garage and work on it here rather than fighting with the unit situation. Princess was driven out of the unit, clutch has now started slipping (another job I'll likely be doing at home) and I had almost no turning circle because of how low it's got on the leaking side. Replacement displacer is working, happily, the leak is definitely from the bodge so that compression joint can't arrive soon enough. Princess is idling better and needing less choke now that it's been moved about a bit more regularly so I hope I'll continue to see improvements on that front, it never was a car that liked to be stood about doing nothing. When I have the Princess home I'll finish off the paintwork that needs doing, I can take my time properly that way. I got the nearest thing to a compliment on the Princess from one of my harshest critics today too of something along the lines of "I never thought I'd see you get this far", which is like a normal person saying "wow, that's really coming together now! Well done.", so that's something. Waiting on info for a possible metal thermostat housing replacement on the Rover, I have a 50 mile maximum range before I need to put more water in which is a bit rubbish, especially since it's so nice to drive just lately. Bit of an up-and-down day today all in. Always feels good to get behind the wheel of the Princess even for just a little bit and it's amazing how much difference just seeing it move and having a coat of paint on it makes to doubters' opinions. Sorry, no pictures, I completely forgot to take any camera with me.
Last Edit: Sept 18, 2016 17:17:15 GMT by vulgalour
Smiler
I no longer own anything FWD! Or with less than 6 cylinders, or 2.5ltrs! :)
Sept 18, 2016 19:13:20 GMT
That princess is looking fantastic. I really like what you have done to the front end and looking forward to seeing the rear all fitted up.
As ever, watching with keen interest.
www.Auto-tat.co.uk'96 Range Rover P38 DSE (daily driver) '71 Reliant Scimitar SE5 GTE 3.0ltr Jag V6 Conversion '79 Reliant Scimitar SE6A 3.0ltr 24valve Omega Conversion '85 Escort Cabrio 2.0 Zetec - Sold '91 BMW 525i - Sold '82 Cortina 2.9i Ghia Cosworth - Sold '72 VW Campervan - Sold '65 LandRover 88" - Sold
vulgalour
Sept 19, 2016 17:09:29 GMT
Compression fitting arrived today and I was going to replace that bodge pipe on the Hydragas pipe on the Princess. Unfortunately what I thought was a 12mm pipe is actually a half inch pipe (12.7mm) so the fitting I bought is not suitable. I've found an imperial compression joint but it's going to have to wait until I get paid before I can get it. Hints on where I might get a single 1/2" compression straight coupling suitable for 400psi welcome, there may be a cheaper alternative out there I haven't found yet. Imperial fittings aren't the easiest thing to source online outside of the USA.
Some of the Renault engine has come home in the boot of the Rover, the rest of it is sat in the boot of the Corsa which will be coming back tomorrow by which time the Plastigauge might have arrived so I'll be able to make some progress on all of that. Couldn't quite fit the engine block in the Rover's boot, in hindsight I should have just put it on one of the seats where there's more space.
Sept 19, 2016 19:23:30 GMT
Try Think Automotive in Isleworth for the compression fitting. They do just about any fitting know to man - give them a call & explain what you need & they will advise on the correct fitting for you. Think Auto
vulgalour
Sept 19, 2016 22:04:12 GMT
Had an interesting conversation tonight with a friend of mine about Metros. Coincidentally, in my searches for suspension alternatives not only did I find Hydragas replacement coilovers for Metros and Minis, I also came across a snippet of information about 'individualising'. I'd dismissed this having not found much more about it until my friend asked if I'd considered it.
On the Metro and MG F, the hydragas displacers are linked to give a nicer ride, MG Fs have damper assistance to help give better handling too. Thing is, if you remove the connecting pipes and replace them with schrader valves on each displacer you can control the height and to some extent the spring and damper rating of each corner individually. There's no reason this can't be done on the Princess too since it's the same fundamental system just fitted to a larger car. You lose some of the comfort and wallowing and it won't soak up the bumps quite as well but it also means if a displacer does fail you only lose one corner, not one side of your suspension.
It's out of budget at the moment, though not expensive (we think about £30 a corner for the valves, need to double check prices) and completely reversible if I want to go back to a connected pipe. I fancy giving this a try because reports on MG Fs is that it improves things quite a bit on the handling front and that's always been a little bit of a weakness with the Princess.
qwerty
Club RR Member Number: 52
Sept 20, 2016 6:29:27 GMT
Paul Y
Sept 20, 2016 7:07:25 GMT
Give Mark at Hydrahose a call 01245267381. Tell him Paul with the Orange 56 sent you - probably charge double... P.
vulgalour
Sept 23, 2016 16:33:24 GMT
Happily I found a 1/2" compression fitting that just needs two new olives (ordered) before it can be fitted to sort out the Princess. Best of all, it didn't cost me anything. The other thing was getting the Renault home which revealed it's a very narrow little car, almost too narrow to fit on the tracks of the flatbed truck. Best of all, it's short enough that I have enough space at the back of my tiny garage to work on the engine comfortably. Plastigauge also arrived so I can get on with the measuring soon.
Last Edit: Sept 23, 2016 16:42:13 GMT by vulgalour
qwerty
Sept 23, 2016 21:23:20 GMT
Having the Renault so close at hand should help, you can now just pop out when you have a spare few moments.
Also means if you get fed up you can just wander back in the house for a brew! Keep up the good work, always enjoy these updates.
Tom
