glenanderson
Club RR Member Number: 64
Aug 15, 2023 11:21:26 GMT
Best of luck mate.
If I had the resources I’d have it off you today. I’m sure you will have no problem finding it a new home.
Take care.
Aug 15, 2023 12:47:37 GMT
Sorry to hear of your troubles, hope life gets better soon
eurogranada
Just for support: all the best. I hope it's only temporary and all will be better soon.
Aug 21, 2023 18:50:05 GMT
A year ago I'd have snatched it out of your hands, not in the right place mentally to do a new project now though.
Good luck with the sale & I hope things look up soon.
Just a note to say I hope things work out for you and good luck with the sale.
Aug 22, 2023 11:44:08 GMT
Oh no, sorry to read this V - hope any bumps in the road are minor ones chap.
And GLWTS too, Steve
vulgalour
Club RR Member Number: 146
Aug 22, 2023 16:50:06 GMT
Even though it's up for sale, the video updates will continue for a little while yet on this project. This time around, it's dealing with woodworm.
One day I will let you all know why this has happened, even if things change and for some reason we end up being able to keep it. For now, I'll just keep posting the content because it's useful knowledge for anyone wanting to know what this type of car is like to work on. Thank you for all the kind words too, this is a much loved car both by us and seemingly everyone else that encounters it, definitely going to be a sale we regret.
saloon
Aug 22, 2023 20:44:06 GMT
GLWS, echo others’ thoughts. Was hoping to get to a first drive video where we could see and learn about pre select gearbox driving in action. AEC Regent Three with pre select gearboxes ( think London Transport RT) bus drivers made it look easy but it probably isn’t.
Last Edit: Aug 22, 2023 20:44:48 GMT by saloon
vulgalour
Aug 23, 2023 20:26:56 GMT
It's actually not that bad, at least on our very brief test drive early in the project. Hubnut did recently do a Lanchester LD10 review showing the gearbox in action.
saloon
Aug 23, 2023 22:13:11 GMT
Thank you for posting the Hub Nut piece. Very informative - like the RTs something to take time with and enjoy the drive which is a very pleasant experience (as a passenger).
vulgalour
Sept 2, 2023 16:32:55 GMT
Made and fitted my very first brake line today. Amazingly, I even remembered to not only put the unions on before doing the flares, I also put them on the right way around. Fitting the new brake cylinder was a bit of a war due to the spring washer thingy (there's probably a tool for this that I don't have) and I could finally adjust the shoes properly to get the drum on and off. To celebrate, even though the in-tank pump is definitely running, no fuel is getting to the front of the car. This is a problem that has developed all on its own in the last fortnight or so because that's when I last had the car running with absolutely no issues. I'm really hoping it's not a blocked pick up in the tank because getting the tank to seal when you remove the pump and sender is just about impossible, and Princess tanks are predictably unobtanium. They're also triangular so it's not even like you can easily use a generic one either. OH WELL. Tomorrow I bleed the brakes and I'll have a furtle to see if I can encourage some fuel up to the front of the car so it can be turned around to do the other rear drum. New welding gas is ordered so when that arrives I can crack on with the arch and sill repairs on the Princess and the door corners on the Maestro. MoTs (even though the Princess doesn't need one, I'd like it for peace of mind) and insurance swap and shuffling about so the Maestro can find a new home and the Princess can be back on daily duties full time again. At some point during all of this I also need to find the time to make a more serious effort selling the Lanchester than I currently have. There's only so many hours in a day, that's the only problem.
glenanderson
Sept 2, 2023 16:48:37 GMT
You can always try the old “blow back down the fuel line from the other end” trick.
vulgalour
Sept 2, 2023 17:21:04 GMT
It's definitely an option. I noticed on getting back from an errand just now that there's what looks like a damp spot under the car right underneath a rubber section of fuel line. It's not wet or petrol smelling now, but it might have been earlier and I just didn't see it. Hopefully it's just a pipe that's gone pourous or something, it'll be very easy to replace it if that is the culprit.
vulgalour
Sept 2, 2023 19:04:28 GMT
Okay, it's not that pipe I thought it was and I can blow through the fuel line with my own lungs so there's likely no blockage. However, the battery is flatter than a flat thing so maybe it's just that the pump isn't able to spin fast enough to push the fuel all the way. Battery on charge overnight and we'll try again tomorrow.
vulgalour
Sept 3, 2023 15:44:54 GMT
Super minor tiny update here. Did a couple of cosmetic things, namely put the gutter and waist trims back on, this helps make a bit more sense of why the colour is split where it's split and why the A pillar isn't painted black. The other thing I've done is very quickly splashed some satin black on the driver's side B pillar. I don't really know why I never got around to doing this since I did the other side. It's good to have it done now at least. Fuel filler flap will go back after I've thrown some black paint in the pocket and found some suitable screws/bolts that don't have chewed up heads like the originals. I'm not sweating the state of the paint that was rollered on since it looks tidier than the patchwork it was in and I can go back and do a better job at any point. For now, I want to tackle all the other outstanding niggly bits for that sense of accomplishment and motivation boost, something that finally having the rear brakes back together has given me.
vulgalour
Sept 3, 2023 17:50:23 GMT
Battery charged, hooked up, and tried again. No joy.
Now, I can suck the fuel through (and I can also confirm unleaded still isn't my beverage of choice) but it comes through with a lot of air like when you're trying to suck the last of a milkshake up with a straw.
I also tried jacking the back end up to let gravity help with no joy *but* I did try some percussive maintenance and the tank sounds very, very empty.
I begin to wonder if the sender has just got stuck showing the car as having half a tank of fuel when it's actually empty. I can get the car to run on contact cleaner (it's all I had to hand, don't judge me) so I've no worries about the car actually running and while I do have a mechanical fuel pump I could fit that means digging into the back of the garage to find where exactly I put it.
I'll get a fresh jerry can of fuel, dump that in, and try again probably tomorrow because I cba to do it tonight.
vulgalour
Sept 4, 2023 12:50:25 GMT
Victory! I drove it for the first time in FOREVER. Trouble is, there's a fuelling issue with it. I did think the tank was empty and the sender had got stuck at half gauge but after putting 10 litres of fuel in it the gauge did move up the requisite amount. I also can't get it to start without manually priming it and after that it runs fine under load but will gradually lean off and die at idle. I can hear the pump running, the battery is fully charged, I topped up the dashpot just to be sure, the float in the carb doesn't look to be sticking, I've got no curse word in the fuel filter and I can't see any air bubbles appearing in the filter when the car is running. I do know the fuel in the car is old but it's also now diluted with fresh new fuel so I wouldn't expect that to be the issue in this instance especially since the fuel doesn't smell varnishy and looks nice and clean. Throttle and choke cables are moving freely and when it is running it's pretty happy. It's only at idle I'm getting the issue. I do wonder if it might be drawing air in from somewhere, or if the electric in-tank pump is perhaps weak and on its way out. When I can get to the back of the garage again I'll have a rummage for the mechanical pump and fit that, see if that solves the issue. If it does, I'll just run that since I've done that before with no bother and it's a far easier solution than trying to get the pump out of the tank and then seal the tank up afterwards.
Sept 4, 2023 16:57:22 GMT
Usual check would be to take the fuel line off at the carb and stick it in a jar, then see how much is flowing, should be coming out at something like a litre per minute.
vulgalour
Sept 4, 2023 17:46:33 GMT
I'm not getting really any fuel flow at all from the pump, it's not pushing fuel as far as the filter... and I'm a bit confused about what it's doing because I can get it to run which I wouldn't expect if the pump wasn't doing anything.
I look to be getting a reasonable 13ish volts at the pump so I don't think it's an earth problem. Sender is also apparently reading properly since the gauge went up when I put more fuel in. Under load/throttle the engine runs fine, enough fuel gets to the front. If you come off the throttle the idle returns to a normal level but then drops off until the car eventually stalls as if fuel starved. To restart, you have to manually prime it because the pump doesn't seem able to force enough fuel up to the carb. However, if when it's idling the idle speed begins to fall, you can revive it by pumping/feathering the throttle and it will go back to running okay for a bit until the idle drops off again. Could this be a carb issue? Or am I missing something else obvious here?
Sept 4, 2023 19:44:24 GMT
If you can't get any fuel with the pump on at the carb something is wrong with the fuel supply, could be many things, all you can do is work your way back down the fuel line checking it's not crushed or any rubber sections have not collapsed, if all that checks out it can only really be the pump. Unfortunately you may also not be able to draw through the electric pump with an external one so it may need to be changed or replaced with a simple dip tube and external pump.
