I have an Audi A4 diesel estate, mot until april. I have replaced the cam belt, water pump, tensioners, viscous fan, all wheel bearings, all breaks and drivers side drive shaft. Fitted with coil overs and comes with a spare engine, gear box and some od's and sod's spares. Was in daly use until end of last month. Bad points. Engine uses water, i was putting about a litre a week in but never bothered me as it still drove fine. Looking for £500 or a swap for a mig welder (min 240 amp), tyre fitting machine, hot jet wash, body shop equipment or valeting equipment/detailing products.
Call Matt on
07563345459
Also had a full set of steering arms.
Abs light on but only needs the o/s/r pickup ring putting back on. (supplied)
Call Matt on
07563345459
