Mar 18, 2015 13:31:28 GMT |
It's that time again where I start the thread asking forum goers to post up there projects which the deadline for completion is RRG15!
so how about it, post up a few pics showing your projects, big or small that the deadline is RRG15.
I'll go first!
my mk1 undergoing a new engine swap! from a small block 1.3 8v to a small block 1.4 16V
still lots left to do, like skim the head and bolt it down along with getting it running and set up on the carbs..
Last Edit: Mar 18, 2015 13:34:34 GMT by retromk11
Long Time Rambler
Mar 18, 2015 18:04:46 GMT |
My project is relatively minor to yours truth be told! My project for RRG is this:  The issue? Many little issues to fix and not alot of time. ATM it will not even pass an MOT. My plans include: -Rebuild rear dampers (one of them is leaking badly) -Reinstate interior (mostly sourced for the best part, but some parts remain to be acquired -Redo some of the wiring (it could be better and prevent issues later on) -Change tyres (they are old and 2 of them pretty close to the limit it not on it) -Redo geometry -Change some bits on the engine, including replumbing the chargecooler, changing the breather tank to a more effective one -Enjoy it. It is not alot but with work training and transitions time and no garage to work in (I can barely get into the car from the garage!) it will be interesting to see if I complete it  .
adam73bgt
Mar 18, 2015 18:24:46 GMT |
I'm determined to be back at RRG in this  It needs:
- Suspension seeing to
- Sebring arches fitting
- Wider wheels sourcing and fitting
- Mild engine rebuild and supercharging
- Interior redoing
We'll see how much I manage to get done before the gathering... still need to find somewhere to work on it haha
Mar 18, 2015 22:23:20 GMT |
I'm slimming down the fleet by one...... My target is to get the bottom half of this  Attached to the top half of this  And get whatever comes out the other end to RRG15 I reckon I'm a 1/3 in so far
berendd
why do I need 3 keys for one car?
Mar 19, 2015 10:03:28 GMT |
my plan is to bring this:  but a lot of work still to be done: -welding the floors shut -fitting 2.8 twincam engine and box -wiring (complete mess right now) -LPG install but steadily getting there
Last Edit: Mar 19, 2015 18:43:10 GMT by berendd
Mar 19, 2015 10:35:24 GMT |
just removed the front off the limo for better access installing this small lump in it
Last Edit: Mar 19, 2015 10:35:55 GMT by deaddave72
'88 Cadillac Brougham hearse (white) '91 Carlton GSi 24v '72 Dodge dual cab pick up '99 Mercedes S55 AMG
Mar 19, 2015 18:53:55 GMT |
GavinJ
MGB 3.9 v8 Sebring
Mar 19, 2015 21:49:06 GMT |
 Should make my first ever RRG in the 'b, missed the last few years shows completely through the frustration of it not being finished, but this year is looking very promising!!
Last Edit: Mar 19, 2015 21:55:10 GMT by GavinJ
Mar 20, 2015 16:03:22 GMT |
keep them coming. looks like I've got a lot less than you lot to do!
carltonx
yardie in brum
Mar 20, 2015 17:18:42 GMT |
get some paint on !
Potentially offensive comment deleted. You are welcome to remove this text, but not replace it with more bigotry. If the need to express that opinion is particularly important, please let me know and I'll delete your account for you. Maximum signature image height: 80 pixels.
MonzaPhil
Mar 20, 2015 18:31:48 GMT |
 Perhaps not in time for this year's gathering. Sent from my word, I don't remember eating that! using proboards
This is now a clicky linky!
Mar 20, 2015 21:32:20 GMT |
 Perhaps not in time for this year's gathering. Sent from my word, I don't remember eating that! using proboards I stand a better chance of getting the limo there than you would that one!
Davenger
It's only metal
Mar 20, 2015 23:38:06 GMT |
Should be there in this after a 2 year absence  Once the bodges have been undone courtesy of Dez, I might get round to lowering it and finally fitting a stereo
MonzaPhil
Yay. Hope it's done!
Sent from I'm not out of bed yet using proboards
Mar 23, 2015 18:37:40 GMT |
Don't even get me started about my Volvo 360 but... Hoping to have finished my ABF (2.0 16V) conversion on my 1.3 1985 mk2 Golf   Still need to take engine out again to swap to a 9" brake servo and 22mm m/c New inner cvs Reassemble front end the start by stripping the rear end to replace fuel tank, inline pump, fuel lines, rear beam, brakes from drums to discs and then reassemble it all and crack on with splicing CE2 loom into CE1 fusebox so I have barely started really!
Last Edit: Mar 23, 2015 18:44:03 GMT by 360beast
Mar 23, 2015 20:05:59 GMT |
in absence of your 360, ill bring the GLT again this year  it needs an MOT first
Mar 23, 2015 20:16:23 GMT |
I'd like to make it in this if the bumpers ever come back from the chromers. Still along way of finished
Mar 23, 2015 20:46:24 GMT |
in absence of your 360, ill bring the GLT again this year  it needs an MOT first Will it have the b230 in before the show? This time you won't be on my  when we leave though... Atleast I hope lol
Mar 31, 2015 11:11:08 GMT |
anymore for anymore?
regiment9ine
@regiment9ine
Mar 31, 2015 11:34:43 GMT |
making this presentable and dialling in the fitment, not a million miles off
