So here we have my 1991 Audi 80 2.0e auto for sale.
I purchased this car with 58k miles on from the original owners son in 2013, as a ex Audi employee ive always had a "thing" for older audis and when this popped up locally with the owner thinking of scrapping it i had to save it.
The original owner was Lord Willis of Chislhurst (http://en.wikipedia.org/wiki/Ted_Willis,_Baron_Willis) and as you may imagine the car never really moved out of the area having been used by his wife upto when i purchased the vehicle.
At 60k it had as its recommissioning.
Also the radiator does weep, once again i had planned to replace this and included in the sale is a brand new rad bought for £280 !!! and also a thermostat for piece of mind.
All the pics are post accident so you can see for yourselves there really isnt anything wrong
James, Maidstone, 07981277256
[/ul][/li][/ul]
- New Oil Filter
- Oil Change
- New Air Filter
- New Spark Plugs
- New HT leads
- Coolant change
- New Timing Belt
- New Timing belt tensioners
- New mirror glass
- New Aux Belt
- New lower pulley bolts
- New Temp Sender (Gauge)
- New Temp Sender (ECU)
- New Temp Sensor Housing
- New Hella NOS rear light as one was cloudy
- New Number Plates
- New Wiper Blade
- New Audi heated washer jets (at massive expense) due to blocked orginal ones
- New Battery
- Rear Lights resealed with the incredibly expensive audi gaskets for piece of mind
- 4 New tyres
- Original wheels zinc coated the powdercoated black
- Crack in screen that has been there since ive had it, and been a MOT advisory but never got worse.
- MOT Advisory on lower arm bush needs replacing.
- Outer CV boot deteriorating.
[/ul][/li][/ul]
