Is that the wedge shaped one? Yup I had one before although a 2.8 V6 One with a V8 should be very good fun! Got a nice picture today showing off the new wheels. I know it needs an inch or so out of the ride height, it is in the list of things to do! I have a set of adjustable coil overs if interested?
Thanks for the offer but it is already on GAZ Golds. Just had it mapped. Making more boost than expected but Shaun is happy that it is safe. I don't think the clutch will last long though, it is FAST! Thankfully it all went without issue, no smoke, no leaks, all safe, all good I will get a video up soon but I cannot get the grin off my face. Shaun estimates 350-400bhp with his butt dyno!
350 seems reasonable with about 8 psi boost. There was a gap with a 4.6 silly cam and Buick heads with twin turbos on his Tvr and he was getting 365 at 8psi and 385 with 10psi 👍🏼
Those are some good figures!
Too many projects, not enough time.
Video of the first drive out
Wimping out early but its cold outside and have already had partial throttle wheelspin in 3rd!
Awesome work. That sounds evil!
top TOP work! Makes all the right noises and goes like the clappers.
You should be proud of this one :-)
Bit of a coincidence, my dad bought a 4.6 Westfield Seight this week. Not seen it yet but it sounds EPIC :-D
I do like a V8 Westfield! I have got the boost back under control and now stable at 5psi. Feels quite tame now as it was almost hitting a bar before Plan is to get the gearbox out on Friday ready for the new clutch but this might change as I have a lot to do on the Trabant, Land Rover and Cappuccino!
You need to start wearing a open neck shirt exposing your hairy chest and medallion , and chain smoking Marlboro red tops .
#manscar
froggy
I do like a V8 Westfield! I have got the boost back under control and now stable at 5psi. Feels quite tame now as it was almost hitting a bar before Plan is to get the gearbox out on Friday ready for the new clutch but this might change as I have a lot to do on the Trabant, Land Rover and Cappuccino! I thought it sounded a bit under pressure on the video , should take 10psi without too much drama and it's always cheaper to turn the boost up rather than down
Nov 11, 2016 18:48:15 GMT
Gearbox out today ready for the new clutch. The old one was starting to slip after the first day. My friend Lew turned up to help at about 3pm (I already had the car on stands, exhaust off and gearbox drained) but we had the box on the floor by 5pm so probably only 3 hours all in. Unfortunately I died in the process
Nov 11, 2016 22:05:47 GMT
poor show on dying dibs the chim' in your "estate"
Nov 12, 2016 20:02:34 GMT
Took the clutch and flywheel off today. I have a McLeod 10.5" clutch ready to go on but it needs the flywheel re-drilling to fit it. I will get a fresh friction plate and release bearing for it as well, and get the flywheel and pressure plate resurfaced at the same time. I have had the flywheel lightened in the past (21 pounds down from 28 as standard) so would rather nt have to replace it if not needed Bit bigger than standard: Tight fit on the flywheel!
Nov 12, 2016 20:28:03 GMT
That old clutch doesn't look like it's slipped much. Sure it's not them tyres lighting up. Awesome car and great work. Any regrets on the blow off valve exit location.
69 Herald 13/60 with Turbo 1600 MX5 engine, Lexus 5 link rear end, 17in wheels,300mm ventilated disc's and subaru 4 pot calipers
It was started slipping in 4th and 5th so backed off after it happened a couple of times hence why it's still pretty good. No regrets with the screamer so far, it sounds evil and has no effect on normal driving so I'm pleased
It was started slipping in 4th and 5th so backed off after it happened a couple of times hence why it's still pretty good. No regrets with the screamer so far, it sounds evil and has no effect on normal driving so I'm pleased Does it sound like how I described mine? A cross between and artillery barrage and a helicopter taking off when on full throttle? 😃
Colonelk
Club RR Member Number: 83
Nov 16, 2016 22:10:47 GMT
Sounds fab in the video Love how this has come together
Nov 25, 2016 14:52:57 GMT
Who here likes a before and after picture? Clutch slave cylinder rebuilt Propshaft bare metalled and painted Screamer finishing pieces laser cut and now fitted I will be shortening the screamer a bit one the gearbox is back in (at the moment the back of the engine is supported on a jack) Heavy duty clutch arm turned up. I could have welded a bit of plate onto my old one but oh well I have also bought an action camera with external mic so expect some better videos once she is back on the road
Nov 25, 2016 15:21:12 GMT
Forgot to add I had the flywheel re-drilled by Mass Racing to take the new McLeod clutch
Nov 25, 2016 18:46:29 GMT
ah the old "land rover" mod on the clutch fork. i did that to mine!
