Hi
I was surfing this site yesterday after discovering it in Retro Cars. I stumbled upon a tread by Claymore whom I know from TorqueCars. He suggested that my project may be of interest to members of this forum.
It is a 1967 Lotus Elan that I have had for over 40 years and been rebuilding for the last 12 after being laid up in a leaky shed for 19 years (broke it at 1985 Street Car Championships then kids came along). The rebuild started off as an engine rebuild and new chassis but quickly escalated into a full blown nut and bolt radial modification saga.
The car had 168bhp at the wheels and ran high 12s when I broke it. However, shopping trolleys have more power these days so I had to rethink the power plant. Decided on a YB turbo as it is not too far removed from the twin cam and the engine mounts are in the same location. Up till then I had built all my twin cam engines but decided to get the YB built by someone who knows what they are doing. Settled on 520bhp/450lbft on pump fuel. This was over 10 years ago and I never expected the rebuild to take this long, although there have been many hiatuses due to life getting in the way. However, it is now, finally coming together and, hopefully, will be running by the end of 2016.
Rather than bore you with the trials and tribulatins up to this point I will just list what has been done and what is still to do. The engine was built over 10 years ago so the spec is a little dated but will do for now.
Sierra Cosworth 2000cc 4 cylinder modified engine:
Approx 520bhp on pump fuel
Ford Motorsport 200 block
Long studded (6)
Balanced knife-edged lightweight WRC crank
8.2:1 compression ratio
High pressure oil pump
Big winged WRC sump
Steel windage tray
Group A rods
Mahle pistons with R4 pockets
Group A ported and gas flowed 2WD head
Hydraulic lifters
WRC phase sensor
Escort WRC inlet manifold
Piper BD14 inlet and exhaust cams
Piper vernier cam pulleys
Piper valve springs
WRC steel head gasket
4WD exhaust manifold
Custom made 3” exhaust system (Primary Designs) Plasma coated by Zircotec
T4 RS500 turbo with 60 trim compressor housing and 360 degree bearing
.31 Actuator
8x Seimens injectors
Distributorless ignition system (camshaft pickup)
Wasted spark coil pack (Motorcraft) and high performance plug leads
Big wing baffled alloy sump
4WD steel flywheel
Twin plate cerametallic Alcon clutch assembly
4 bar MAP
Life full race F88 ECU
Custom made lightweight wiring loom by DC Electronics
Anti-lag system
Launch control
Traction control
ABS wheel sensors for above on all wheels
Full throttle pneumatic gear change system
(homemade)
Custom made alloy radiator and intercooler
Hi-Spec 4 pot alloy front calipers and larger diameter lightened grooved and drilled discs
Hi-Spec2 pot alloy rear calipers and drilled and lightened discs
Elite il300 6 speed sequential gearbox
Lightened propshaft
Sierra Cosworth 7.5” 3.85:1 rear diff fitted with Quaife ATB
Custom made gun barrel drilled halfshafts
Custom made rear hub assemblies
Lightened CV joints
Uprated chassis to beyond 26R specification (by Graham Hatherway Racing) to cope with up to 650bhp
Uprated (Tony Thompson Racing) Lotus Elan rear bottom wishbones
modified so as to be adustable for toe in
Custom made (GH Racing) rear top wishbones (“Rose Jointed”) and hub carriers
Custom made adjustable aluminium front top wishbones
Spyder bottom front wishbones
Alloy (Pace Products) front wheel hubs
Standard bushes in all suspension parts that haven’t been “Rose Jointed”
Droop limiters all round in lieu of anti-roll bars
Fully bespoke B.A.D dampers and Eibach springs with tender springs on rear
Rear dampers now inboard
Standard steering rack but reconditioned and secured with solid mounts
Floor mounted brake-bias pedal box assembly
Hydraulic clutch assembly
No ICE
Carbon fibre seats (pair), dash, centre console, boot, bonnet, door skins and cards, rear wheel tubs and bulkhead
Lexan windows including windscreen
Custom quick release steering wheel with inbuilt switches and containing dash
Full structural roll cage
Lap and diagonal seat belts for everyday use and full harness for track day and drag racing use
2 gallon foam filled alloy fuel tank
Holley blue top lifter pump
1.5l collector tank
Pair of Bosch 044 MotorSports high pressure fuel pumps (205l/min @5bar)
High flow filter.
600 series Aeroquip dash 8 fuel lines
Fuel pressure regulator with dash 8 return feed
Hydraulic handbrake
Custom rear light clusters
Bodywork modified to accommodate 3-piece 15x8” alloys with 225/40/15 tyres on the front and 3-piece 15x10.5” alloys with 285/35/15 tyres
at the rear
Front splitter
Rear diffuser
Front and back bumpers moulded into bodywork
Underside smoothed
Lithium battery
No lights
Lightweight 80amp alternator
Carbon fibre hardtop
Most bolts replaced with either titanium or aluminium alternatives
Component positions optimised to help in balancing car weight
Probably dark grey satin paintwork
If anyone is interested I can post a few photos.
Long studded (6)
Big winged WRC sump
Steel windage tray
Group A rods
Hydraulic lifters
WRC phase sensor
Piper valve springs
.31 Actuator
4WD steel flywheel
4 bar MAP
Anti-lag system
Launch control
Traction control
(homemade)
Lightened propshaft
Lightened CV joints
No ICE
1.5l collector tank
High flow filter.
Hydraulic handbrake
at the rear
Front splitter
Rear diffuser
Underside smoothed
Lithium battery
No lights
