HI all! I've been lurking on the forum for a while now so i think its about time i start my own thread. I bought my Rover back in the autumn of 2015 from a chap in Dudley, Birmingham. i owned it a full 40 minuets before its first breakdown on the M5 on my way back down to Somerset, overheating massively due to a seized thermostat (covering my girlfriends car who was following behind in rusty water). All in all it was a good solid car but it had suffered mainly from not being used. i believe it was restored in 2002ish but before then it had spent at least 10 years in storage. The first photo i took of the famously unreliable machine... First thing to go wrong after the overheating on the way home was a good month in to ownership. the rear trailing arm that connects to the di-dion elbow gave way driving along some lumpy moor roads at 1am. This as it turns out is quite a common fault on p6's these days, years of rust and fatigue take their toll. Thankfully i was on a straight road with no traffic, doing 60mph i thought id had a blowout and the whole back end started sliding around, not a pleasant experience! I repaired it using 3mm stainless steel, so hopefully it'll last much longer! I also checked and strengthened up the other side to make sure that it wouldn't happen again! More to come..
Last Edit: Mar 3, 2016 21:12:02 GMT by george94
1953 Austin Somerset (parts car) 1952 Austin Somerset 1965 Singer Vogue Estate 1970 Morris Minor 1980 Triumph Spitfire 1987 Citroen 2CV
120y
Lovely motor
1996 Renault Clio MK1 1.4 RT Auto
i made 2 door skin repair panels 12 in high and new inner frames for my friend . his is a v8 , throaty thing it is
"Things going wrong part 2" I decided the car needed a service so i went about removing all the spark plugs, i got to number 1 plug and i sheared in two with almost no effort at all. This being my only car at the time gave me a bit of a problem. I started off by trying my luck with one of those easy out tools which i now know was a complete waste of time, because as you try to turn them to remove the damaged part they also expand the thread in the hole making them impossible to remove. Needles to say the one i had snapped in two.. Eventually it became apparent that the head would have to come off, i'd never worked on an overhead cam engine before but as it turned out it wasn't as hard as it first appeared. Just had to take care that the top chain tensioner didn't dissapear down in to the sump! With the head off i was then able to drill out the remainder of the spark plug. With a new head gasket and spark plug i threw it all back together ready to drive up the NEC classic motor show the next day! I took it for a Polish car wash on the way home, they all wanted photos taken next to it! And on my way back down from the NEC someone got a photo of me chugging down the M5!
I must admit I do like a P6. Hope its running better now.
It did run better for all of about 6 hours peter96 but the clutch then gave out on the way home from the NEC and bits of the pressure plate started shooting through the bell housing!! Thankfully though it was still drivable and i managed to limp it home. All the bits whizzing around had made a bit of a mess but thankfully nothing was badly damaged. I managed to find a NOS pressure plate and clutch on ebay so that went on along with a new release bearing. Then of course it had to be taken for the obligatory test drive The car ran really well then for the next couple of months though slowly i was beginning to notice a loss in power to the point that changing down to second for hills was becoming normal! Chatting to the people at the P6 club stand at the Bath and West classic show pointed me in the direction of a burnt out valve on number four cylinder. Sure enough!.. I was planning to put hardened valve seats in the head but i still wanted to squeeze a bit more POWER out of the Rovers engine so after scouring ebay for a few weeks i came up with this! A NOS cylinder head for a 2000 TC and i also found a pair of twin HIF6 carbs off of a 2200 TC local to me. Took a bit of cleaning up with new needles, jets and gaskets.
Great story - and I do like your garage radio!
67 VW Split bus 69 Beetle Cab 96 Jeep Cherokee XJ Sport
Those SUs have cleaned up nicely. Amazing what a bit of elbow grease can do.
That is a lovely car...
I've had a couple of P6's and I need another one soon!!!
***GARAGE CURRENTLY EMPTY***
Good to see another survivor! Bookmarked! ~~~ A bit of a hijack: Would a P6 dashboard be butcherable to fit a Range Rover Classic? There is a certain similarity and room for more gauges and switches would be less of a mess with a dashboard with more room from the factory in the first place rather than hang on's or horrible circular saw cut outs.
1986 Mercedes 200 (W124) (Standard and daily) 1976 Peugeot 404 1800 Stickshift (Standard - awaiting complete resto, engine done) 1984 Ford Cortina (P100) LDV - Cab and chassis restored, interior and glass not fitted, brand new 3 liter engine (last 110kw Sierra XR6 engine fitted and married to 5 speed Toyota Gearbox), load body needed.
Great story - and I do like your garage radio! Thanks! it works a whole lot better than any modern radios I've had! Before putting the engine back together i had to make up a new set of valve shims to ensure i had the correct gap on each valve. I had to get them made up at a machine shop out of high carbon steel then have them hardened.. a lot of faff just to adjust a gap! I sourced an exhaust manifold (ebay again) and bolted that and the carburettors on to the car. I had to shorten the forward exhaust pipe as the SC has a cast manifold and the TC a tubular.I got it all together and went to turn the engine over and the camshaft lobe shattered on the number 8 valve… It being a NOS head i had forgotten to have a locating dowel made for the cam carrier. so i had to get one made up, i also had to find a replacement cam and cam bucket.. That solved that problem, and when i next tried the engine fired first time! Then there was the small matter of cutting out some of the rot on the sill, With all that done the car went like a bat out of hell and ran really nicely for almost the best part of a year with only minor pits and pieces going wrong, mainly overheating because of a hole in the radiator..
Good to see another survivor! Bookmarked! ~~~ A bit of a hijack: Would a P6 dashboard be butcherable to fit a Range Rover Classic? There is a certain similarity and room for more gauges and switches would be less of a mess with a dashboard with more room from the factory in the first place rather than hang on's or horrible circular saw cut outs. Not sure i can help you with that one having never really seen the interior of a classic range rover.. My P6 being the base model only has the single strip speedo and a clock. I'm thinking it might be upgraded for the TC instruments at some point as they have all the fancy gauges such as oil pressure and an ammeter!
Mar 11, 2016 12:01:06 GMT
the cylinder head has hardened seats already, because its alluminium
looking at the sandy textured combustion chamber in the head, then subsequent nibbled exhaust valve, i'd say there is some serious detonation going on. the valve damage will be a symptom rather than the cause
Mar 11, 2016 16:29:30 GMT
Nice car .Reminded me of my v8 .Fitted new wings and did a lot of work on it, One place to watch is behind the rubber boot covering in the boot area by battery Its the anchor point for shockabsorber top mount the rust just inside the bot hole.
Mar 13, 2016 18:43:56 GMT
Mar 17, 2016 19:48:24 GMT
Mar 26, 2016 12:37:53 GMT
Mar 27, 2016 18:12:54 GMT
Oct 10, 2016 20:04:45 GMT
