Thought I would start a thread for my Mk3 Cortina, I must have bought four 2 doors before I found one that wasn't either hanging or full of filler as a base to work from.
Purchased this one owner, 50k miles, garaged all it's life 1600L back in 2006.
![](http://img.photobucket.com/albums/v82/Cyrix/S3500018.jpg)
Stripped it down and briefly turned it into a Benetton special edition.
![](http://img.photobucket.com/albums/v82/Cyrix/P3043630.jpg)
Stuck some new metal to it, really just sills and arches. Found a Mk3 Savage bonnet in the back of someones lockup in Luton, these things are so rare I couldn't believe my luck.
![](http://img.photobucket.com/albums/v82/Cyrix/DSC00408.jpg)
![](http://img.photobucket.com/albums/v82/Cyrix/P3290025.jpg)
Added a 3.0 Essex V6.
![](http://img.photobucket.com/albums/v82/Cyrix/P4120018.jpg)
![](http://img.photobucket.com/albums/v82/Cyrix/P4120024.jpg)
I've upgraded pretty much all the running gear as they tend to handle a bit like a boat as standard.
![](http://img.photobucket.com/albums/v82/Cyrix/DSC02358.jpg)
![](http://img.photobucket.com/albums/v82/Cyrix/260184_10150296174383784_511863783_9035002_6503066_n.jpg)
![](http://img.photobucket.com/albums/v82/Cyrix/IMG_1625_zps8fc867f7.jpg)
One of these turned up, then another - kind of put the brakes on car time/money for a couple of years.
![](http://img.photobucket.com/albums/v82/Cyrix/1528464_10152389323578784_4657512108394080907_n_zpswhudexqm.jpg)
Decided my home made exhaust sounded terrible and looked even worse. So paid someone better at sticking metal together to make one for me. Tig welded stainless.
![](http://img.photobucket.com/albums/v82/Cyrix/IMG_7123_zpsmmtrflkm.jpg)
![](http://img.photobucket.com/albums/v82/Cyrix/IMG_7131_zpsn8nm6kuu.jpg)
Going over the axle presented some issues, the upper radius arms knocked on the exhaust as it got close to the bump stops. I was searching for a solution and found a guy on here who had used arms from an Nissan 200SX that happen to be pretty much exactly the same, did a bit more searching and found they did a kinked version for super low cars. Sorted my problem out very easily.
![](http://img.photobucket.com/albums/v82/Cyrix/IMG_7147_zpshl6u4kt7.jpg)
![](http://img.photobucket.com/albums/v82/Cyrix/IMG_7159_zpsluhr0dg8.jpg)
Which pretty much brings me to where I am now, I've been having a bit too much fun in it this year and the gearbox isn't thanking me for it. I've a couple of plans for over the winter -
Replace gearbox with a 5 Speed one or Swap the Engine/Box out for a V8 with 5 Speed gearbox. I think the latter might win as buying or modifying a bell housing could work out expensive.
Upgrade the brakes to discs all round, I've some Brembos for the front and a Granada setup for the rear. The 2.8 Capri vented setup and 9" rear drums are OK but could do with being better.
