Hi folks,
Well after a couple of years of fun my legacy GX is being broken up and sold for parts to fund my new obsession of converting a 1994 BC saloon 2.0 L into a turbo saloon...
So I'm keeping the 4.44 sti gearbox, all other parts of the car are for sale!
I will sell the car complete if someone makes me a reasonable offer in the region of £500 for the car on steel wheels minus gearbox and some time pieces.
MOT is good until April 2017, The car will have a 4.44 rear diff still fitted but I don't think it's an LSD as it's off an auto not an sti. Rust inside the rear arches and I did a bit of butcher job rolling them to accommodate the 16x8 wheels after the lowering and the different offset. It's got a few stamps in the service book up to 80k, I've got a few receipts for various bits but the service history is not comprehensive by any means!
Engine Ej25 on 140k miles, head gaskets done at 100k (bang on schedule from what I've heard!)
Engine has always had regular oil changes at about 8-10,000 miles using fully synthetic and subaru filter. no problems with oil or water since head gaskets done. impreza turbo solid flywheel and clutch conversion done using skimmed flywheel and new clutch, bearings and pressure plate(oem spec parts) at 110k miles. If you want or need the loom you can take what you need with the engine. £500 ono
All doors and bonnet available too, message me or comment with requests.
Full leather interior and door cards, ok condition no tears or holes, just usual slightly worn bolster and leather looks well bedded in.. £100
Also got a GTB bonnet and front bumper in dark blue both a bit tatty but intact and just in need of a few bits of filler and a respray, £45 for the bonnet and £20 for the bumper.
Sti 4 pot front brakes with recently replaced(less than 5k ago) brembo oem discs and black diamond predator pads, all working well, paint job not great. £300 for the set up.
impreza Sti alloy front lower arms £50 THE PAIR
Bilstein GTb shocks with H&R sport -40mm springs all working well, i think the shocks have probably got about 140k on them as the car they came off was on 100k and that was when I bought the car. top mounts all appear to be working smooth still not banging or clunking yet! £300 for shocks with springs.
later spec headlights rev D? possibly, had to modify the loom and mountings to fit them after getting them cheap, so ended up costing me more in the ned!! one light has an epoxy repair to the top fixing point (nearside light). £40 pair
Jaguar XJR 1990 wheels 16x8 et43 with 4x 225/50/16 dunlop sp sport 2000e on the tread limits wheels were custom welded and drilled as 5x100 by Ian Jemison Engineering in York, I think I have still the receipt for this somewhere it wasn't cheap but they look damn cool in my eyes! £500
Set of goodyear ultragrip M&S tyres 225/50/16 nearly new, hardly worn at all, near enough 8mm tread all around! £200
All items would be best collected due to size etc.. offers considered on everything! Located in Malvern Worcestershire message or contact me (Tom) on 07858634545.
engine still in car so can be heard running etc if wanted. More pictures available on request and better pics of wheels to follow once I clean them!
