BMW E30 320I Convertible for sale.
126,000 miles, I've owned this car for just over 3 years and it's only done about 1400 miles in that time (This is the main reason I'm selling).
3 months MOT
4 previous owners, last owner had the car for 22 years and used it for a daily driver so was very well maintained.
Since I've owned the car the following work had been done:
Full Service including spark plugs
Distributor cap, rotor arm and ignition leads replaced.
Battery replaced
Throttle cable replaced
Set of coilovers with new top mounts front and rear.
Anti roll bar "d" bushes replaced
Anti roll bar links replaced
Short shift gear linkage with new bushes fitted on the linkage end
Wheels:
Dare RS 16''x8'' with 195/45/16 Avon tyres Front
Dare RS 16''x9'' with 205/45/16 Avon tyres Rear (one wheel has been kurbed about 1/3 around the wheel)
Original alloys are also included but could do with a refurb.
Biting point on the clutch is getting high but is not slipping at the minute. I have already got a new Sachs clutch and the new linkage bushes for the gearbox end which is included with the car.
Bad points:
All four arches need attention (see pictures), I've found plenty of places that sell repair panels for this.
Dash is cracked (very common problem)
Roof has a hole in the back window which has been taped up but could do with replacing, also the roof isn't very water proof so will either need treating or replacing.
Car has been garaged since I've owned it and was only used in the summer.
