Hello!
Thank you for your kind words.
As I'm spending the sunny weekend in the office there's not much to report in terms of progress. So I thought it would be sensible to compile a list of things wrong with the car. This will serve me well as a reminder of what needs to be done and give you a pretty good idea of what you'll get yourself into if you consider getting one of these on the cheap. But first, let's answer your comments and questions:
Yeah, I think so, too. Plus I've noticed that one of the rear tires is unevenly worn. The new setup will probably get the alignment nearer to what it should be for the moment, but it has to be checked anyway. As for the plate frame: it was about the same price as a box of fags so I got lucky there.
Thanks again! I too have no idea why people don't seem to mind driving around with next to no airflow into the cabin. The filter is relatively cheap and changing it only takes a screwdriver and five minutes of faffing.
I'd say do it. These cars are currently on the brink of extinction and it's a good time to get a peach for relatively low money or a slightly rough one like mine for surprisingly little cash. I think in a few years time examples like mine will all be broken for parts which makes finding one much harder. But be warned that these cars do feel very modern, but are in need of old-car levels of TLC. At least that's my experience.
To shed a bit more light on that thought here's my to-do list for the CLK in no particular order:
Mechanicals
- fine-adjust the gas pedal linkage / electric motor for better pedal feel. It's currently way too sensitive.
- fix two small oil leaks on the engine
- check timing chain tension
- do another oil change after 1000 miles since I could see a bit of crud inside the oil filler neck on first inspection
- find out if the fluid on the front of the gearbox means something serious (already cleaned that off, let's see if it returns...)
- Slap on new brakes before winter. There's much meat still left, but one disc is juddering
- Check all crank case breathers for carbon buildup
- See if I can find a bit of extra smoothness on the engine idle. These engines should run virtually vibration-free. Mine isn't as smooth as it should be.
- Fix one exhaust bracket
- Find the reason I can't move the gear lever into the manual gate. The gearbox is fine, the previous owner reported of hearing a bit of plastic shatter in the centre console.
- Recharge the A/C-system and get rid of the wet-dog-smell every time you turn off the A/C
Electrical
- find out why the car indicates a blown bulb every time I switch on the main beams. All bulbs work as they should. The light switch is the most likely culprit.
- have the 2nd key to the car fixed and maybe have the ignition lock restored / resoldered. These are reported to fail on high-mileage cars.
- fix one broken bulb in the instrument cluster
- find out why the sunroof loses its memory from time to time and has to be retrained to properly open/close in one continuous motion instead of just moving 2 inches at a time
- polish the headlight lenses for better visibility
Body
- Clay, compound and polish the whole thing: I just can't stand how scratched and unloved it looks!
- Remove rust from the tailgate
- Remove rust from the rear arches
- Remove first hints of rust from the driver's side sill
- Remove rust from the passenger door
- Remove rust from the passenger side front wing
- Replace the front wing on the driver's side since it's probably too far gone
- Remove rust from the bonnet
- Get rid of the dampness inside the driver's side indicator on the wing
- Repair crack in the front bumper or replace it alltogether
- Leave lots of €€€ at the painter's
- Replace all seals on the driver's side window. These have shrunken badly and have started causing wind noises after I adjusted the window
- Take the driver's side door apart and find out what the mechanic who was in there before me left unbolted. The door makes noises untypical for a Mercedes on closing. Namely: rattling.
- Find out why there's a draft from the lower driver's door when the sunroof is open. The seal looks fine and is correctly in place so I'm a bit baffled as it stands.
- Replace sunroof seal and fine-adjust the mechanism for less wind noise
- Service and lubricate windscreen wiper mechanism
- Polish driver's side window and windshield to get rid of all those fine scratches
- Repaint exhaust tip
Interior
- Give it all a blöödy good clean
- Restore the leather to good health. It has been conditioned regularly so it's nice and soft. It just looks unloved.
- Restore pneumatic bolsters in the driver's seat since it's much slower in operation than the passenger side
- Replace one seat adjusting leaver since it's just gone AWOL
- Repair two rips in the plastics (one on the glove box and one on the centre console)
- Replace speaker grille on the passenger side door
- Replace driver's side door card (it's just shaggered)
- Replace broken cover on one vanity miror
- Polish all interior wood parts
- Get rid of a pretty intense air freshener smell
- Repair cupholer for the rear seats
- Replace cup holder for the front seats (half of it is missing)
Goodies and gadgets
- Find and install an original COMAND 2.0 navigation unit. I'm currently negotiating the price for a reconditioned one. These things were painfully expensive when new.
- Find and install the wheels I want. I've settled on these which were a factory option back in the day:
-Find and install an original auto-dipping rear view mirror with a yellow illumination-LED. DONE! I'm yet to figure out how I can take a picture of its effect for you. It bathes the whole interior in a warm, amber light at night. Already love this feature.
- Install an original PDC-system. The CLK is really hard to see out of and park. Especially after the trip to the painter's I don't want to immediately scuff up the bumpers!
- Find and install collapsible outside mirrors
- Find and install a switch panel including the one missing switch compared to mine: the switch for the alarm system. I just like the look of a switch panel with no blanks.
Phew. It's quite a list already and I feel like I've missed a few things, too. But fixing a car like this is more than half the fun!
Cheers,
Felix
Ride height on the rear looks so much better, really makes the car look more purposeful than broken as you said. Good call.
Interesting about those drain holes, that's some poor design right there. And that's coming from someone who had a MK1 Eunos so I know all about clogged drain holes and rust..how much did that plate cost you? It's a nice little addition. Looks smart.
That pollen filter seems to be a common theme, seems they never get replaced even though that's the air you're always breathing...
Great work.
Great work.
Nice work I like these cars and it's another one on my list to own at some point
Mechanicals
Electrical
Body
Interior
Goodies and gadgets
Cheers,
Felix
