A friend of mine bought one of these complete with AMG 18" Monoblocks for 400 2 years ago, lovely motor to be a passenger in but never drove it. He removed the wheels and sold it for the same amount a few weeks ago. Went to the local Scrapyard yesterday and guess what was sat in there... he was bit gutted when I showed him. Shame really, a lot of car for the money.
Ouch, that indeed hurts a bit. But I guess you cannot save them all sadly. There comes a point in time where all necessary repairs sum up to more money than the car is worth... at which point cars like these usually get broken for spares. Which is perfectly understandable - most people give me funny looks when I tell them that I actually enjoy fixing an old car.
Lovely job you've done on yours, it really doesn't look as old as it Is, and you cannot beat pillarless doors. Shame Mercedes skimped so much on the steel/rust protection.
Thank you! I'll do my best to keep this one going.
As for Saturday. The day started with new engine mounts - a job people speak about in not the most pleasant tongue. Access is rather limited, but it's not as bad as the internet wanted me to think it is. Both of them were well and truly shot, have a look at a 200.000 miles one vs. the 0 miles one:
The difference in height shows you even more why it needed replacement. The inner structure had simply disintegrated so that the whole mount was basically split in half.
Prop shaft flex discs where next and the car got a new set of brakes in the front:
So much better. The car now drives much more pleasant with the engine mounts making the biggest difference. It really is a night-and-day kind of difference: the slight vibration at idle is now gone, so are about 90% of all driveline noises. It's unbelievably quiet inside. All of this adds up to the car feeling 10 years younger giving me a slight indication what these CLKs must have felt like when they were new. Quite impressive.
So it's time for a bit of an update on that never ending to do list:
Mechanicals
- fine-adjust the gas pedal linkage / electric motor for better pedal feel. It's currently way too sensitive.
- fix two small oil leaks on the engine
- check timing chain tension
- Check all crank case breathers for carbon buildup
- Find the reason I can't move the gear lever into the manual gate. The gearbox is fine, the previous owner reported of hearing a bit of plastic shatter in the centre console.
- Recharge the A/C-system and get rid of the wet-dog-smell every time you turn off the A/C
Electrical
- have the 2nd key to the car fixed and maybe have the ignition lock restored / resoldered. These are reported to fail on high-mileage cars.
- find out why the sunroof loses its memory from time to time and has to be retrained to properly open/close in one continuous motion instead of just moving 2 inches at a time
Body
- Clay, compound and polish the whole thing: I just can't stand how scratched and unloved it looks!
- Remove rust from the rear arches
- Remove first hints of rust from the driver's side sill
- Remove rust from the passenger door
- Remove rust from the passenger side front wing
- Replace the front wing on the driver's side since it's probably too far gone
- Remove rust from the bonnet
- Leave lots of €€€ at the painter's
- Replace all seals on the driver's side window. These have shrunken badly and have started causing wind noises after I adjusted the window
- Find out why there's a draft from the lower driver's door when the sunroof is open. The seal looks fine and is correctly in place so I'm a bit baffled as it stands.
- Replace sunroof seal and fine-adjust the mechanism for less wind noise
- Service and lubricate windscreen wiper mechanism
- Polish driver's side window and windshield to get rid of all those fine scratches
Interior
- Restore the leather to good health. It has been conditioned regularly so it's nice and soft. It just looks unloved.
- Restore pneumatic bolsters in the driver's seat since it's much slower in operation than the passenger side
- Replace one seat adjusting leaver since it's just gone AWOL
- Repair two rips in the plastics (one on the glove box and one on the centre console)
- Replace speaker grille on the passenger side door
- Replace driver's side door card (it's just shaggered)
- Get rid of a pretty intense air freshener smell
- Repair cupholer for the rear seats
Goodies and gadgets
- Find and install the wheels I want.
- Install an original PDC-system. The CLK is really hard to see out of and park. Especially after the trip to the painter's I don't want to immediately scuff up the bumpers!
- Find and install collapsible outside mirrors
- Find and install a switch panel including the one missing switch compared to mine: the switch for the alarm system. I just like the look of a switch panel with no blanks.
