Hello! It's been a while since I posted on this forum!
I have for sale a very rare Toyota Yaris T-Sport TS 1.5 in Red Y Reg
First things first, I realise the pictures have the plate covered, I did this for my Ebay ad, I can assure you it's one of the early TS' (Y Reg)
MOT September 10th 2017
Currently on under 106,000 Miles
Full V5 Document Present
2 Sets of Keys
Interior is in good condition overall
Completely standard car to my knowledge which has had a lot of recent work carried out (from wear and tear) with receipts to prove:
6/09/16 New Front Discs and Pads
6/09/16 New Rear Discs and Pads (including New Caliper)
6/09/16 New Offside Rear Shock Absorber
6/09/16 New Front Anti Roll Bar Link
6/09/16 New Front Wiper Blades
6/09/16 Headlight Align and Refurbish
8/09/15 New Catalyst Converter
8/09/15 New Middle and Rear Sections of Exhaust
13/07/15 New Battery
29/04/15 4 X Matching Tyre's including Wheel Align
It also has Full Service History up until 36,000 Miles in Toyota Yaris Folder
Points to Note:
As can be seen in the pictures it does have large areas of Lacquer peel. it started off as just small areas but has now spread. The Red colour is still bright red and there is no rust on the body work. A few barely noticeable scratches which have been buffed out.
Small areas of pitting/bubbling on the alloys.
The Exhaust (whist completely replaced just over a year ago) I think does blow slightly. It's only really noticeable in higher gears under load (i.e accelerating from 30 mph in 4th etc.) and started the first day after it was replaced, I think one of the joins is not 100% flush (but has since passed an MOT like this)!
The Brakes (whilst again replaced recently, less than 6 months ago) squeal occasionally but brake fantastic!
The front two Tyre's will both require replacing ASAP. Only one was an advisory on the last MOT but I think they are both now pretty close (the rear two still have decent tread left!)
It probably does need an Oil change soon, It holds it's oil and water and only very occasionally needs topping up, however is probably due.
Advisory on the last MOT was the Tyre as listed above / Corroded rear fuel pipe / and..........slightly strange....Tow ball/hitch not fitted at time of test! You may be able to see in the pictures it does indeed have a Tow bar which I have never used in my approx 20k miles of use, so I decided on day one to remove the Tow ball (is in the boot) as i'm not sure what or why you would want to Tow anything in a Yaris, but is there if desired!
Some general rust on the underside of the car.
I can honestly say this car has never let me down and having recently driven it over 1000 miles in 2 days it was very comfortable, economical and sporty when required.
Having said all this the car is sold as seen with no refunds, however I do believe I have explained it as best to my ability. Worth noting the car has been standing for a few months (occasionally turned over) and have since bought a new battery for it!
As you can probably tell I took some of that from my Ebay listing!
Any questions feel free to ask!
Cheers!
2 Sets of Keys
Points to Note:
Cheers!
