Oh, if it helps with shaft lengths the Rover Metro short shafts (the splined section) are 404mm long. MGF short shafts are 380mm long, but I don't have the length of the long shafts written down.
Where did you find those threaded bush ends? I like them!
smith4
Nov 27, 2023 20:36:28 GMT
smith4
Nov 27, 2023 20:42:04 GMT
The leafspring is off for some work, so the LSD is getting some paint.
When the longer bolts arrive, I can mount the spring perch to the LSD.
Then when the spring is back, these can be installed and wishbone lengths determined.
smith4
Nov 27, 2023 20:42:46 GMT
smith4
Nov 27, 2023 20:43:55 GMT
smith4
Jul 10, 2024 21:47:49 GMT
Subaru LSD now in. Adjustable wishbones made up. Temporary wishbone brackets tack-welded. Wheelarches in progress. Lots done. Lots still to do.
Jul 15, 2024 14:41:21 GMT
This is still so cool.
smith4
Oct 14, 2024 17:24:22 GMT
@stealthstyle Cheers dude - more to come
Last Edit: Oct 14, 2024 20:35:08 GMT by smith4
smith4
Oct 14, 2024 17:25:25 GMT
zeberdee Yeah, thanks dude. Just had a really difficult year with stuff, so hopefully going to get a load more work done on it soon.
Last Edit: Oct 14, 2024 20:36:05 GMT by smith4
smith4
Oct 14, 2024 17:25:46 GMT
Last Edit: Oct 14, 2024 20:36:47 GMT by smith4
smith4
Oct 14, 2024 17:52:24 GMT
A little update - 2nd house move since I started this thread in 2018!! Front arches/wings have had some more clearancing for the wheels to turn and the tyres to not catch on things - still need to do more clearancing. Front wheel arches chopped off, wings cut (radiused), outer bits of inner arches slitted (is that a word?) to help re-shaping to get ready to be be tapped upwards and welded to wing, and bulkhead/firewall re-shaped a little with hammer. 2nd camber spacer put back on (for fun) as well as to see where the bulkheads needs amending with varied camber adjustments, because when the wheel goes through it's up and down suspension movements and camber adjustments more areas of the bulkhead need amending. I've now come to the conclusion cutting the bulkhead, re-shaping a little further back, and then welding will give the best clearance for the tyre on full lock, and look better than re-shaping with just a hammer (which is what a lot of racing Spitfires/GT6s had done). Just to re-mention, my GT is for fun at low speeds, not high top speeds. I don't recommend this amount of camber for any other reason than fun! But if you do what to look into the science of it, check out the 1967 MX-1 Camber car made and tested by Milliken. He had camber adjustment up to about 50 degrees negative, and testing also included things like toe and castor. Next up will potentially be clearancing for the rear tyres, which means cutting/radiusing the rear wings to stop the body sitting on the tyres. Once all the clearancing is done, I can position the front and rear arches for best fitment, allowing for necessary suspension travel and steering lock. And eventually weld them in place Before the work on the front arches: After arch/wing work and extra camber spacers (1x 1/2" spacer per wishbone mount = about an extra 4 degrees): Yes - the bottom of the sill is wonky I chose the cheaper Steelcraft make of panel rather than the more expensive Heritage make, and I had to amend the top edge of the new panel to get it to sit in line with the door bottom, and it still didn't sit quite right. I'm aiming to trim a little off the bottom edge and spot-weld along to make it flatter, but the sill will still be wonky overall:
Last Edit: Oct 14, 2024 20:39:58 GMT by smith4
mylittletony
Club RR Member Number: 84
1967 Triumph GT6 (Smith4)mylittletony
@mylittletony
Club Retro Rides Member 84
This thing is utterly ridiculous, in the best way. Makes me smile every time I see it, please carry on and get it out to some shows ASAP
