Good bits
-Mechanically great, has been really looked after by somebody and has never let me down once and has flown through last 2 MOT with no adviseries.
-Super economical with a tiny engine and only weighing about 650kg!
-Interior is great, everything works (even the ancient AM only radio)
-Has a new battery and oil + oil filter put in very recently
-Has a hidden killswitch for the engine to prevent theft
Neutral bit
-some lovely person decided to snap the driver side mirror off in the night. However, I've fixed it with a bigger one that adjusts from inside the car (amazing I know). So this is only bad if having an asymmetrical car bothers you, otherwise it's an upgrade.
-gearbox is a four speed
Bad bits
-outside is a bit on the tatty side, with bad lacquer peel on the bonnet.
-the exhaust has come loose and punched a hole in itself so will need sorting (new one is £40 on eBay), still drivable though as is not bad
-has a short MOT, due June 22nd
Neutral bit
Bad bits
