Ray Singh
More German exotica in my garage now
Jun 13, 2018 13:43:36 GMT
I have a 320i BMW come in today. He tells me that the car might be over heating. The coolant level was a little low, but after topping up it seemed fine. We drove the car and the coolant level stayed put. However the engine gets very hot. There is no indication that the fans come on either. The temperature gauge sits bang in the middle of hot and cold.
So is the car overheating?
ferny
Club RR Member Number: 13
Jun 13, 2018 13:52:17 GMT
Stick an infrared thermometer on the hoses.
Milord
Jun 13, 2018 14:13:31 GMT
Currently: BMW E46 320i Touring BMW E34 525TDS Touring VW T3 panel van 1.6d Opel Kadett C1 Caravan 1.2 Fiat 411R
slater
Club RR Member Number: 78
Jun 13, 2018 15:55:58 GMT
What does 'very hot' mean.
In my book if it's not boiled up it's not overheated.
Jun 13, 2018 16:17:39 GMT
Hi, As said use a infra red thermometer because dashboard temp gauges are not precision instruments.
Colin
Ray Singh
Jun 13, 2018 19:39:55 GMT
Thanks all. By very hot i mean the car gets from cold to hot in about 5 mins of driving and then it stays hot for hours after a drive. Its not boiling up.....
Anyone got an infared thermometer i can borrow?
Jun 13, 2018 19:44:55 GMT
If you have to ask for the signs of overheating,it's not....😂 Boil hard,spray boiling water all over....or go home.😉
Last Edit: Jun 13, 2018 19:46:52 GMT by Deleted
Jun 13, 2018 20:35:40 GMT
BMW temp gauges are very heavily damped. The needle will sit at 12 o'clock throughout a wide range of actual engine temperatures. In my experience (if the gauge is working correctly) the needle going beyond 12 o'clock would be a sign that something might not be right, but otherwise I wouldn't be worried. Also, depending on what model BMW it is, it'll likely have a viscous fan and the electric fan will just be for air con. Certainly the case with e36s.
Yes, my daily driver (2000 Audi) is the same - the electronics in the dashboard will show spot-on 90 degrees (centre of the gauge) for anything between about 82 and 100 degrees.
Jun 14, 2018 10:17:44 GMT
BMW temp gauges are very heavily damped. The needle will sit at 12 o'clock throughout a wide range of actual engine temperatures. In my experience (if the gauge is working correctly) the needle going beyond 12 o'clock would be a sign that something might not be right, but otherwise I wouldn't be worried. Also, depending on what model BMW it is, it'll likely have a viscous fan and the electric fan will just be for air con. Certainly the case with e36s. Depends which BMW it is. If it's an E46 they are damped, yes. M3s in both flavours are exceptions to the rule. If it's an E9x it will only have a light. If it's the latter they do run hot, and it's normal. Why? Emissions and fuel economy is why.
LowStandards
Club Retro Rides Member 231
Jun 14, 2018 10:56:37 GMT
Jun 14, 2018 12:06:10 GMT
obd reader and log the coolant temps. We had a fiesta a while ago that was similar. Fan switch often is set much higher than you would imagine too. Fiesta was 105 degrees but we have seen some as high as 115 before they operate.
Its not broken, its resting! Max signature image height: 80px
Jun 14, 2018 17:18:07 GMT
If it isn't chucking water out it isn't overheating.
Jun 16, 2018 11:30:15 GMT
I had a 330Ci (e46) that suffered overheating due to a previous owner removing the electric thermostat, this is in the fan controller circuit which meant that although the thermostat was always open it prevented the fans from running (slightly redundant mod I thought).
The car was ok most of the time, it got "hot", i.e. when stuck in traffic you could smell hot coolant and when shut off the engine would be hisssing and ticking as it cooled down. Temp gauge only moved off "fine" to "hot" after I was stuck in traffic in the middle of summer and the car was proper overheating (steam coming out under the bonnet and that smell.....). It only indicated "meltdown" (goes off the scale and a red light comes on) after the coolant header blew up as I was finally escaping the traffic. Good times.
On the e46's the fan controller can be overridden by pulling the fan fuse and using some spade terminals to add a remote switch inline with the fuse and then taking a permanent 12V feed from another point in the fuse box. Also there are 3 temp sensors, fan one is on bottom rad hose, there is another on the thermostat housing and one in the block somewhere.
Jun 18, 2018 16:57:58 GMT
If it isn't chucking water out it isn't overheating. On some engines, prolonged heating over 110 degrees (well before the water comes out of the heater tank) will cause the engine to become soft. I know M52s and possibly M54s suffer from this, which is why quite a few out there are now running on helicoils as a result of the blocks going soft and the studs being pulled out of the head; Initially it looks like a head gasket, but of course the HG is only part of the problem.
Last Edit: Jun 19, 2018 17:05:52 GMT by ChasR
