Hi
I have in my head an idea of a “hot rod” Range Rover classic.
It would be rear wheel drive, 4 door lowered,
I have little experience but have put together a parts list
Jaguar xj6 wishbone front end & steering rack & brakes,width looks very similar
Corvette ls1 v8 400hp😀
Nissan 350z manual gearbox adaptors available
Rear axle ?. Jag?
Prop, exhaust, engine mounts will need to be manufactured
Radiator?
Or a complete v8 donor car?.( with manual box)
Curse this midlife crisis😡
Help & encouragement eagerly absorbed
qwerty
Club RR Member Number: 52
Look for an entire seperate chassis that the Range Rover body can be dropped over, then Axles, steering brakes etc are all sorted.
Also you can set the body at a good height on the donor chassis.
Tom
misteralz
Jun 18, 2018 11:22:52 GMT
Disagree - you can get a Rangie low without all that. Stock late air suspension can get one down quite a bit and still be comfortable, but the thing that can make a massive difference is coming down a few profile sizes from the stock 205R16 - and it looks a lot better than you would ever imagine, like a purposeful early seventies estate that never existed.
Jun 18, 2018 15:36:35 GMT
Disagree - you can get a Rangie low without all that. Stock late air suspension can get one down quite a bit and still be comfortable, but the thing that can make a massive difference is coming down a few profile sizes from the stock 205R16 - and it looks a lot better than you would ever imagine, like a purposeful early seventies estate that never existed. But the OP wants to dispense with the Solihull ironmongery ........ I agree though, keep the suspension and steering etc and just fit a huge engine..... or just buy an OverFinch and slam it .....
tinker
Probably welding something..
Jun 18, 2018 16:52:32 GMT
As a RRC owner for many many years and just cut all the rust (wasn't much left) from my softdash,now all rebuilt, I would say go with air suspension but uprate the antiroll bars to something the size of the P38 ones.
I also have a Sheer Rover that is fitted with standard springs but also coilovers with adjustable gas dampers, not driven it yet due to a complete rust eradication and then a welderthon to replace everything!!, but I'm sure it will do the twisty bits nicely.
Engine, Yes the 4.6 did suffer from liner problems, but if you get a later cross bolted one you should be fine, I have a 300bhp one in my P38..cost a bit to get there but its light weight and bits easy to get, saying that rather than the ls3, try the ls from a 3rd gen Camaro, very cheap and performance bits easy to get from the states, or a lexus 1uz, cheap, strong, reliable...
Good luck with the build.
Jun 19, 2018 13:20:49 GMT
I'd be tempted to keep the rangie suspension but modify it to your needs And then just drop in a big block with a T56 gearbox RWD
A lot of work involved in getting it really low but it should look good done A bit like this
1992 240 Volvo T8 1955 Cadillac 1994 BMW E34 M5 (now sold ) 1999 BMW E36 sport touring x2 1967 Hillman imp Californian "rally spec" 1971 VW bay window (work in progress) 1999 Mazda 323F 1987 Jaguar XJ12 All current
Jun 19, 2018 13:21:29 GMT
I didn't add the photo
Jun 19, 2018 13:58:10 GMT
Jun 19, 2018 14:51:11 GMT
I would love this image to be slammed if possible?, it’s the look I am after, steel wheels & patina😎 no electric toys, no air con no abs manual gearbox & 400hp👍 Thanks for your views Standard suspension is not an option, I have had a Range Rover classic on air suspension, on its lowest setting, on the bump stops it is a very harsh ride & still too high any lower & the axle will e too close to the engine I am drawn towards a jaguar x300 xj6 front end complete with brakes, steering rack, etc, for clearance & possibly jag rear? There’s a jag breaker near me who will let me check out the parts required
sowen
Club RR Member Number: 24
Jun 19, 2018 15:10:06 GMT
How much custom fabrication are you willing to do and are you planning on chopping the chassis to fit stuff or not (not wanting to get into the BIVA discussion now)? I think it'd be cool if you could modify the Jaguar running gear to fit the Range Rover chassis with as little mods as possible, maybe with the front wishbones mounted above and below the main chassis rail? Rear could be tricky unless you can run the driveshafts at a slight angle too?
What about a small body drop so you don't have to hack the chassis about if you can't mount the suspension to get it low enough?
Jun 19, 2018 15:31:39 GMT
Looks a bit involved😬 Maybe I’ll have to get a front end built ! £££
Jun 19, 2018 19:00:43 GMT
I don’t know where this is going, but I like it a lot
wodge
Jun 24, 2018 22:27:21 GMT
Littlepixel definitely approves of this sort of thing. Here's some photoshops I've done with the same sort of idea in mind. These are immense!! Especially the top one! Someone make them real!!
That Hillman Imp lookalike is wonderful. Someone totally should build that.
Jun 27, 2018 11:47:20 GMT
I'd have said it had a bit more of a 60's Mustang look about it.
It's interesting, but not a Range Rover I'd drive.
Jun 27, 2018 12:20:43 GMT
Littlepixel definitely approves of this sort of thing. Here's some photoshops I've done with the same sort of idea in mind. I feel like if this doesn't happen then the world is missing something. Such a beautiful shape.
Jun 27, 2018 13:34:56 GMT
If you are going 2wd At the front you could keep more or less the standard set up but fit a dropped axle. (could just be a matter of fabricating a new centre section for the standard axle,
For the rear a Jag and low ride height set up will probably mean cutting the chassis rails, some sort of trailing arm set up (Scorpio or older BMW) could be accommodated with out too much cutting around, modify the cross tube to mount on the standard RR position and add a new X member to carry the diff.
Smiler
I no longer own anything FWD! Or with less than 6 cylinders, or 2.5ltrs! :)
Jun 27, 2018 21:20:46 GMT
Littlepixel definitely approves of this sort of thing. Here's some photoshops I've done with the same sort of idea in mind. I feel like if this doesn't happen then the world is missing something. Such a beautiful shape. That was my favoutite too.
www.Auto-tat.co.uk'96 Range Rover P38 DSE (daily driver) '71 Reliant Scimitar SE5 GTE 3.0ltr Jag V6 Conversion '79 Reliant Scimitar SE6A 3.0ltr 24valve Omega Conversion '85 Escort Cabrio 2.0 Zetec - Sold '91 BMW 525i - Sold '82 Cortina 2.9i Ghia Cosworth - Sold '72 VW Campervan - Sold '65 LandRover 88" - Sold
Scimitar has a chassis with a wheelbase dimension close to the Range-Rover, so that might be an idea.
As does a TVR Cerbera, but a rolling chassis of them might be a bit expensive.
Click picture for more
alecf
Jun 28, 2018 11:47:01 GMT
Hi I have in my head an idea of a “hot rod” Range Rover classic. It would be rear wheel drive, 4 door lowered, I have little experience but have put together a parts list Jaguar xj6 wishbone front end & steering rack & brakes,width looks very similar Corvette ls1 v8 400hp😀 Nissan 350z manual gearbox adaptors available Rear axle ?. Jag? Prop, exhaust, engine mounts will need to be manufactured Radiator? Or a complete v8 donor car?.( with manual box) Curse this midlife crisis😡 Help & encouragement eagerly absorbed Scrap the nssan 350z box idea, they are fetching too much money now the drifting lads use them. I had one mounted to an audi 1.8t engine mounted in a spaceframed landrover but the ratios weren't the best and one thing and another. I chopped the bell housing to bits to weld a new section in for the starter. When we replaced it for a sequential last yeat I stuck the Nissan box on ebay expecting a couple of quid as it couldn't go back in a Nissan now id messed about with it. I got £500 for the big paper weight. and the lad was over the mood he got it so cheap. There are plenty of other cheaper rwd boxes available. Plus the nisan box is 500meters long.
