aaronb
Fezza nearly done
Aug 20, 2018 19:08:45 GMT
Hello rr Does anyone know if I can and where I can get alloy wheels repaired. I have some 1978 slot mags that need two mighty kerb damage welded and repaired. Approx area Max 20 wide 30 CM deep on one alloy I'm near Worcester uk Also is this safe and OK.
Aug 20, 2018 19:34:42 GMT
You state '20 wide 30CM deep' - I deem your use of 'CM' being centimetres - in which case your wheels are scrap
Aug 20, 2018 20:10:12 GMT
Any damage to a wheel larger than 10mm/1cm it's safer to scrap the rim as anything larger the rim will be buckled and more than likely have internal cracks and not safe to use at all
aaronb
Fezza nearly done
Aug 20, 2018 20:14:48 GMT
Sorry a mean mm. OK thank you. Advice taken.
Aug 26, 2018 16:46:59 GMT
Hi,
I’ve seen Huxley motorsport (who I believe are Worcester way ish) fix a fair few damaged alloys.
Might be worth trying him before binning them
Aug 26, 2018 16:48:01 GMT
Aug 26, 2018 17:37:55 GMT
Before you scrap them, talk to Ian Jemison near York - www.ianjemison.co.uk/ - you'll be amazed what they can fix.
