Pics to follow, P&P £4 or collect from leeds.
Titan Tools Imperial ratchet spanner 7 piece set £30
Titan Tools Metric ratchet spanner 7 piece set £30
Speedo repair cable 110" long (cut to size) £10
Silverline sandblasting gun (part no 633629)£10
3 arm gear puller set (75, 100 & 150mm) £10
MSD ignition lead crimping tool (uses vice, produces top notch crimps) £15
Angle torque gauge £5
Brake pipe flaring kit £9
Compression Tester (petrol) £10
Chicagobrand ALden Wrench Open ended ratchet spanners Imperial (3 double ended spanners, 6 sizes) £35
Chicagobrand Alden Wrench Open ended ratchet spanners Metric pn 56049 (10 double ended spanners- ratchet & plain end, 10 sizes) £75
Jag XJ6 4.2 ECU (Jac DAC1210, Bosch 0280 001 109) £40
Jag XJ6 4.2 Airflow meter £80
Rover V8 Stage 3 Big valve heads (1.63"/1.4") Reconditioned. £800
Rover V8 dizzys (several avail) £30 each
Honda Apexi VAFC2 £200
TVR Wedge 390se Original Equipment ECU & AFM £400
Rover V8 Jetronic 4cu wiring loom (suits TVR wedge, SD1, Classic RR etc) £80 SOLD SOLD SOLD
MSD STREETFIRE Universal Ignition Lead Set (part no msd5552) £45
Mintex brake pads MDB2580 (various VAG) £12
Mintex brake pads MDB1325 (Toyota MR2) £10
4" Bench Vice £10
Helicoil style thread repair inserts Approx 150 assorted M5, M6, M8 £30
Genuine new BOSCH LSU4.9 wideband sensor £45
Megasquirt MS2 CPU (This is the master cpu only, can be used to upgrade an MS1 to MS2) £90 SOLD SOLD SOLD
Pertronix FLAMETHROWER MAG X2 8mm spiral wound Spark plug lead. (Black) £3/metre
Integra DC2 UKDM Stock Back Box £20
4" Bench Vice £10
