vader
Club RR Member Number: 93
Hi. I have a Stag with a 38 DGMS Weber fitted. Fitted it new around 8 1/2 years ago. Just recently had some body work done to the car and the shop ran it dry of fuel. New fuel in and ran ok for a short while then started play ping up and cutting out. Found debris in the inline filter and in the carb. I’ve fitted a new filter and cleaned the carb and also measured the float level.
The car will start and tick over on choke and without choke when warm, when I try to drive with part throttle it’s like kangaroo juice has been poured in. Floor it and it’s ok it just doesn’t like part throttle, any of you intelligent people have an idea?
i have ordered an overhaul kit for the carb so will try that too.
Thanks
Triumph Stag Ducati Supersport Shanks’s Pony
vader
Just noticed I’ve possibly put this in the wrong section, if the mods wish to move it?
Used to have a Granada with a 38 Weber that would do the same every so often. Every time it happened I just put my hand over the top of the carb to block it,and rev it at the same time. Then as it was just dying remove my hand quick. This used to flush any c**p out of it and it would run fine again.
1955 Austin A30 1981 Jawa Mustang 1990 Trabant 601 (Tommy) 1989 Trabant 601 2009 Jaguar XF 2012 Toyota AYGO 2018 Scomadi TL
Webers have a series of small holes in the throat just above the throttle plate which are fed off the idle circuit and are there to add fuel at part throttle and provide progression from the idle to main jet, they easily block and cause the symptoms you describe, as above, revving the engine and holding a balled rag over the inlet can creete enough vacuum to suck the dirt out, otherwise it will need blowing out with an airline.
Last Edit: Feb 6, 2019 22:41:55 GMT by kevins
vader
Hi, thanks for the replies. All sorted. A full can of carb cleaner and a light overhaul kit and all is well.
Thanks again
how is the tank inside?
JP
Last Edit: Feb 8, 2019 20:08:58 GMT by Bullstarz
“It Doesn’t Feel Pity, Or Remorse, Or Fear, And It Absolutely Will Not Stop, Ever, Until You Are Dead!”
