voodoo57
That's not 2 metres! come a little...Closer!
Club RR Member Number: 137
Alternative speedo?voodoo57
@voodoo57
Club Retro Rides Member 137
Guy's (and gals)
i have a gearbox from a v6 Omega in the Escort, and because of this, i cannot have a cable made up because of the original set up with the vauxhall and some strange connection between the box and the speedo, what are my options, i need to show proof of mileage, (honestly) Is there a gadget such as a sat-nav?
Phil H
Club RR Member Number: 133
Alternative speedo?Phil H
@philhoward
Club Retro Rides Member 133
Expensive way: www.speedhut.com/ecommerce/product/2585/SpeedBox%E2%84%A2-GPS-VSS-to-Mechanical-Drive-Speed-Converter although you still need to generate a speedo pulse in the first place. A £20 proximity switch picking up on the tri-lobe output flange on the back of the gearbox will sort that. Cheap(er) way - Still get a £20 proximity switch picking up off the lobe, but use a universal speedo from the likes of CAI, VDO etc. Cheaper still - One of the Chinese Acewell-style specials off eBay/CBS etc. Depends if you want it to look OK or just compliant?
voodoo57
@voodoo57
May 17, 2019 13:57:16 GMT
just so that i can show mileage one way or another for the insurance co. just in case, and thanks phiihoward i appreciate the swift reply. (Wanna join my gang?)
