Aug 27, 2019 13:34:13 GMT
So having dragged the HB out of storage I'm trying to make it a bit more user friendly so could do with some door mirrors, I have a real thing about not wanting to drill holes in the body work so the only option may be the clip on style or something with a small stem that could fix to the tiny triangle at the bottom corner of the quarter light which I don't mind drilling as its replaceable
Ideas would be greatfully received!
Aug 27, 2019 13:35:19 GMT
tristanh
Routinely bewildered
Aug 27, 2019 17:51:38 GMT
If you find the mirror let me know
I like the style of the arm on the VW mirror, not sure if the shape of the head is a bit "grandad" if you know what I mean!
I understand what you mean about not wanting to drill the doors. Every time I drive my Firenza, I find myself looking for a mirror when changing lanes, backing into the drive or just if I passed something interesting and want another look. But I can't quite bring myself to drill holes in the doors on the "new" paint finish - it's only been done 20 years.
I had some mirrors somewhere that bolt onto the rain channel on the A-pillar that would get around that. Not sure they'd look all that good though.
Hi, What about what they're fitting to trucks, now cameras instead of mirrors with a screen on the inside? Much more discreet.
Colin
tristanh
Aug 28, 2019 11:22:21 GMT
I found it. I can post it to you if you want to try it, probably cost less than a tenner from Ireland?
Aug 28, 2019 16:25:57 GMT
Thanks Tristanh, I can borrow a selection of mirrors just got to collect them from down south when I go tomorrow, I will try them first and give you a PM to let you know on your kind offer
Sept 2, 2019 18:18:16 GMT
So having dragged the HB out of storage I'm trying to make it a bit more user friendly so could do with some door mirrors, I have a real thing about not wanting to drill holes in the body work so the only option may be the clip on style or something with a small stem that could fix to the tiny triangle at the bottom corner of the quarter light which I don't mind drilling as its replaceable Ideas would be greatfully received! If you don't want to drill into the door to fit mirrors you could cut short the door trim and fit a polished block of aluminium and mount a mirror to it. I had the same problem with my p5b and came up with the idea and all worked well, good vision and the window still opened.
Sept 3, 2019 16:36:19 GMT
^^^ Looks good, that's the type of thing I was thinking of but fitted in the little triangle at the base of the quarter light, I wont be cutting the trim back as it the rare GT spec I got this selection but don't think anything will work But I quite like this black one, the base is small enough to fit on the triangle and being matt black shouldn't stand out as much as chrome
Isn't that black one a Chevette mirror?
