Go on......
Tell me all of the reasons why potential a 23 year old, 140k Miles VR 6 is not the right car to buy.
Thanks for the replies
PS...... if you think I should yog up Β£700.00 on one.... do tell as well.
Dave the mechanic mentioned cam chains (might have been belt?) and top mounts as reasons not to...
...thinking about it, did he mention cam chain/belt is on the wrong end of the engine making it a tricky thing?
Part of me wants one anyway
They are one of VW's better engines, being a sharan parts are shared with the alhambra and galaxy so should be easy/cheap to obtain. The only down side is the fuel consumption.Other than that the Sharan in this spec is a cracking motor capable of gobbling miles with ease (oo0 er missus)
ps don't forget the VR6 comes in more than one flavour and not much is interchangable so be careful
Basically, go for it
Oct 26, 2019 10:06:34 GMT
Dave the mechanic mentioned cam chains (might have been belt?) and top mounts as reasons not to... ...thinking about it, did he mention cam chain/belt is on the wrong end of the engine making it a tricky thing? Part of me wants one anyway Yup. Me too.
Oct 26, 2019 10:11:07 GMT
They are one of VW's better engines, being a sharan parts are shared with the alhambra and galaxy so should be easy/cheap to obtain. The only down side is the fuel consumption.Other than that the Sharan in this spec is a cracking motor capable of gobbling miles with ease (oo0 er missus) ps don't forget the VR6 comes in more than one flavour and not much is interchangable so be careful Basically, go for it Know nothing about different flavours of motor. But claimed 170 factory horses sounds plenty enough. Fuel consumption?? Paaahhhj.... After the Blazer, everything is a nauseating variety of βgreenβ economy. 2-3k mules a year means its not a deal breaker at all.
Oct 26, 2019 10:22:48 GMT
Grizz, they come in 2.8 or 2.9 guise ,12 and 24v respectively .There is also a 3.2 but thats later and rarer
Last Edit: Oct 26, 2019 10:24:21 GMT by Imperial
Oct 26, 2019 10:28:49 GMT
Grizz, they come in 2.8 or 2.9 guise ,12 and 24v respectively .There is also a 3.2 but thats later and rarer Fair enough. The one in the ad linked above is the one. 2.8 liter. Early I guess. Would not stop me buying it, but I know the collective knowledge on here massively outweighs my limited to loving the sound of them knowledge
Oct 26, 2019 10:40:27 GMT
2.9 24v was in the corrado
Oct 26, 2019 13:42:10 GMT
one of the greatest engine sounds out there.
I think the fuel economy is the only downside, the timing chain arrangement is relatively complex but I've not heard of any horror stories, they are indeed between the engine and the flywheel/transmission.
Oct 26, 2019 19:19:34 GMT
one of the greatest engine sounds out there. I think the fuel economy is the only downside, the timing chain arrangement is relatively complex but I've not heard of any horror stories, they are indeed between the engine and the flywheel/transmission. Fuel consumption is not a problem Well...... Seller seems to have disappeared So the search continues
Oct 26, 2019 19:25:07 GMT
Why should I NOT buy a VR6 engined VW ??
....coz poor old prozac will get the hump!
piguin
Oct 26, 2019 23:42:56 GMT
Because it isn't old or Amurican enough?
Why should I NOT buy a VR6 engined VW ?? ....coz poor old prozac will get the hump! This is true. Because it isn't old or Amurican enough? True, but itβs about a functional tool, larger, stronger and more versatile with tow hook than the little van thar can. Prozac is brilliant but I need brillianterrrer. π
Last Edit: Oct 27, 2019 6:30:10 GMT by grizz
2.9 24v was in the corrado Pretty sure the 2.9 in the Corrado was only 12v the same as the 2.8
- '88 MK2 Golf 1.3 c - '07 BMW E91 335d - '94 T4 1.9d
OGDB
Oct 27, 2019 19:33:44 GMT
I have had a 2.9 swapped caddy van and a 3.2. They can suffer with chain stretch but this can be checked in vagcom. Mileage wise Iβve had 36mpg on a good run at fair motorway speeds.
They Respond to turbo conversions very well.
Oct 28, 2019 18:36:40 GMT
Well...
Seems seller has disappeared.
Miffed.
Oct 28, 2019 18:37:21 GMT
PS.
Thank you all for the replies and opinions
Much appreciated
Oct 28, 2019 21:57:32 GMT
What about a Toyota Granvia with the 3.4 V6 petrol auto, mines been converted into a camper so a tad heavier than normal but it still surprises a few people, a few weeks ago it put up quite a respectable show against a late merc estate down the m61 slip road , happy with that ππ»ππ»
Last Edit: Oct 28, 2019 21:58:09 GMT by granvia
Oct 28, 2019 22:48:25 GMT
They Respond to turbo conversions very well. Yes, I have an itch for a 3.2T ...
