Mar 22, 2020 14:18:44 GMT
I have been cleaning up some stock cast iron manifolds, removed surface rust with abrasive paper and wire wheels,and they are now as clean as possible without blasting. Next step is what to paint or coat them with to keep them rust free and looking presentable ? In the past I have not had much luck with the so called VHT spray can paints. I have read about an American product called callyx that is a paste that you apply with a small stiff brush, it bakes on with the heat and can be retouched.Sounds good but has anybody here used it or is there another product that will stay on hot cast iron ?
Cast iron exhaust manifolds.stealthstylz
@stealthstylz
Club Retro Rides Member 174
Mar 22, 2020 16:46:15 GMT
I've tried everything I've ever been recommended and nothing works if it's just wire brushed.
Mar 22, 2020 17:14:12 GMT
Thanks Phil,just done a google search and Amazon sell a graphite product that seems to get good reviews and for the price will try some as it is much cheaper than getting the Callyx from America.
Phil H
Club RR Member Number: 133
Cast iron exhaust manifolds.Phil H
@philhoward
Club Retro Rides Member 133
Mar 22, 2020 17:16:57 GMT
Nothing lasts forever on cast manifolds - but that stuff lasts as long as anything (probably longer than most) and is cheap as chips.
Mar 22, 2020 17:22:38 GMT
A pal of mine always used to get his hard chrome plated as used on hydraulic rams and industrial stuff, it seems to last a very long time and turns a really nice hue of dark blues, much cheaper than decorative chrome plating
Mar 22, 2020 18:32:14 GMT
I used BBQ spray paint on my steel manifold. Don’t know if it will work any different on cast.
Mar 22, 2020 18:59:49 GMT
I saw a place advertising stove enamelling for cast manifolds, no idea how well it worked. I seem to recall it wasn't very expensive, so I might give it a go at some point.
Cast iron exhaust manifolds.Dez
@dez
Club Retro Rides Member 34
Mar 22, 2020 19:07:49 GMT
As already mentioned, it’s down to surface prep rather than the product. They need to be super clean and keyed, not polished smooth with wire wheels. Get them sandblasted and coat them immediately, even leaving overnight can get surface bloom with cast iron from the moisture in the air. Even rattlecan VHT will work if you do this.
Mar 22, 2020 20:04:01 GMT
Thanks for all the helpful replies. I understand the point about cast iron being hard to prep.The casting is pretty rough in places and just about impossible to completely clean up.On old Jags they used to use a finish called vitreous enamel,but I have never seen any company offer it. I suppose stave enamel could also work, but not having tried it could be expensive on parts that are hard to coat because of the rough sand cast finish ?
I'll try to find the ad again, because it might have been vitreous enamelling rather than stove - I don't know the difference. You could probably phone them up for their opinion on what you have - I seem to recall the ad was aimed at exhaust manifolds. Whichever treatment it was, it was not suitable for a steel tubular manifold.
Just in case anyone else wanted to know I tried a little research on the TR6 an E-type forums and the word seems to be that stove enamel will not last and there is a vitreous enamel firm in the Black Country somewhere but they are very expensive and the finish just ends up looking like BBQ paint if you drive your car much. Think I will go with the stove polish, at least it is cheap and can be touched up when needed.
Cast iron exhaust manifolds.ChasR
@chasr
Club Retro Rides Member 170
Mar 26, 2020 16:46:24 GMT
Another choice would be to ceramic coat them.
However, this is expensive and probably only lasts as they have to be keyed/cleaned to death for the coating to adhere.
