M52 steel liner engine with 328i gearbox with:-
E21 release bearing and modded fork
Lightened e30 flywheel and Sachs clutch
E30 325 starter.
E36 throttle cable
M50 manifold and home made fitting kit which keeps the PCV system largely intact.
Modded dipstick
M50 sump
E36 engine brackets with AKG poly bushes
Standard airbox modded a bit
Hoses to fit rad
Throttle heater delete.
Dan Harborow (Danthe) supplied:-
Exhaust manifolds and downpipes
Remapped ECU with EWS delete
Power steering hoses
Steering UJs
Loom
Modded Clio brake booster (no master)
Bmw short shift (z3 maybe)
E36 rad and kenlowe fan and fitting brackets
Engine was taken from my relatively low mileage E36 touring that I have history for. Conversion has been in a car for a long time but not done huge miles recently. Water pump, aux belt , clutch not done many miles really.
It's more or less a complete front end kit. I have got an E30 M3 prop, LSD, brake master and M3 supersprint exhaust to fit the conversion but these are for sale seperately due to their value.
Have a video of engine running before removal. Some of the parts above are still on the car but the engine is out and I could have the kit complete in a few days.
I'll have forgotten something so ask if you are GENUINELY interested in buying. No messers please as I'm a busy man.
Collection only, I'm in Aberdeen so bear that in mind.
£1800.
I am considering keeping the engine, M50 manifold and gearbox for my E36 which would make the 'kit' both cheaper and possible to send further afield but I would really like it to go as one.
E30 325 starter.
E36 throttle cable
Modded dipstick
M50 sump
Hoses to fit rad
Steering UJs
Loom
£1800.
