Sept 10, 2020 15:16:20 GMT
My Vauxhall Carlton has been laid up in a dry garage for 12 years without being started. Someone told me the automatic gearbox won't be any good now as it needs the fluid pumped around it to keep the clutches in good condition.
Will the box be no good if was to start using the car again?
Sept 11, 2020 2:20:10 GMT
Dip and check fluid if it looks or smells burnt drain fluid and re-fill. If in doubt refer to owners manual. If there's no leaks and its held fluid and shows a level on dipstick I'd just run it up to operating temperature.
colnerov
Sept 11, 2020 10:41:16 GMT
Hi, It's not so much the clutches that suffer more that the seals dry out and don't seal so well if at all, and there are a lot in there.
Colin
scimjim
Club RR Member Number: 8
Sept 11, 2020 10:41:23 GMT
I’d change the oil - it degrades with time as well as use.
