melle
South West
It'll come out in the wash.
Mar 16, 2021 11:58:21 GMT
I'm looking to replace the mechanical water pump on my Saab V4 (Ford Cologne engine) with an electrical one to take a bit of load off the balance shaft bearings, and to create room for a few drastic modifications in the engine bay. A Davies Craig EWP80 pump looks like a good option, they are reasonably priced on eBay too. I don't need all the fancy control stuff, a thermo switch controlled one or simply one that runs constantly will do me fine I think, but I like the idea of being able to hook it up to the ECU when (if?) I get my EFI engine ready. The current mechanical pump has never given me any grief, so I'm not looking for uprated flow or anything.
Any other recommendations for electric water pumps, or experiences (good or bad) with electric pumps in general?
Mar 16, 2021 17:27:33 GMT
This is probably worth a look, an aftermarket controller used to run stock OEM Pierburg pumps. Many different pump sizes available to suit different needs, and you could go and get a pump from a breakers yard if you want to save money over the new ones. It is the "fancier" end of control, pump is controlled by PWM but the controller does all that for you, so not necessarily complex from a user perspective. tecomotive.com/store/en/No personal experience myself btw, just looked good to me. And I think I'd personally have more confidence in an OEM designed pump than aftermarket in general.
96 Peugeot 405 Executive DTurbo Estate 89 Mazda Eunos Roadster 88 Citroen BX 16RS Previously Owned: 93 Subaru MV96 Disco 300TDI 72 LR SIII 109" Prima96 Xantia Activa 92 AX GTI 97 ZX Temptation 88 205 XS
lebowski
Hillman Avenger, Clan Clover
Mar 16, 2021 18:12:47 GMT
I run a Pierburg CWA200 from a BMW, along with the Tecomotive controller mentioned above. It works great, and the Pierburg pump is supposedly superior to the Davies Craig items.
The Tecomotive is also great. You can set your target running temperature and it will control the pump and your radiator fan. I haven't done enough miles to say anything about long term reliability, but it gets a thumbs up from me.
melle
South West
Mar 16, 2021 18:29:08 GMT
I like the idea of using a second hand OEM pump (most of the other parts I'm using are repurposed OEM), but I couldn't really find anything other than small auxiliary pumps on eBay for reasonable money. Maybe I need to look better. In my mind the advantage of a Davies Craig pump over OEM ones is that they're nice and compact, and the flanges and be turned in any direction. I thought Davies Craig pumps had a pretty good reputation?
Would there be any merit in using a controller on a non-performance engine? As for setting a target running temperature, can't the same be achieved with a simple in-line temp sensor? I'm probably overlooking something!
lebowski
Mar 16, 2021 19:53:49 GMT
The Pierburg one is also compact. There are loads on ebay for about £30 upwards. You can't run it without the controller though. If you did manage to then it would be running flat out all the time which would use a lot of amps (it uses upto 16.5A).
melle
South West
Mar 16, 2021 21:04:24 GMT
The ones around the £30-£50 mark I saw were all small auxiliary pumps, but I've probably not used the correct search terms. What types of BMW use the Pierburg pump you mentioned? Is the controller a stand-alone thing?
The heater on my car is part of the cooling system, not sure I would want anything other than a pump that runs constantly like the original mechanical pump? If I'd fit a temperature controlled pump I'd need to fit an auxiliary pump for the heater as well? The Davies Craig pump I linked in my opening post draws max 7.5A at 13V and has a flow rate of 80L/ min.
Last Edit: Mar 16, 2021 21:11:39 GMT by melle
slater
Club RR Member Number: 78
Mar 17, 2021 10:54:56 GMT
I've not had any problems with the DC ones.
lebowski
Mar 17, 2021 12:59:32 GMT
'BMW electric water pump' brings up plenty on ebay.
The Tecomotive controller is standalone. In a BMW, the waterpump is controlled by the ecu.
With the Tecomotive, the pump always runs at a low speed even when the coolant is cold, otherwise you would get hotspots around the cylinders. Therefore there will always be some flow through the heater circuit. If you find the flow is not enough, to some extent you could manipulate it by setting the target coolant temperature lower. The pump would then run faster as it approaches the target temp. Another feature of the Tecomotive is that it can continue to circulate coolant and run the fan after you've switched off the engine, to bring the temperatures uniformly down after you've finished driving.
I would think that the DC one works in a similar fashion.
melle
South West
Mar 17, 2021 13:59:56 GMT
It's probably me, but I still don't see the advantage of the controller. I currently have a mechanical water pump, but an electric fan that is controlled by a thermoswitch in the upper radiator hose. This set-up does exactly what you describe the controller does, the only difference is that I need a different sensor if I want to change the target temperature.
I imagine I can control the pump the same way, with the sensor working as a two-speed switch rather than an off-on one, if I always want some flow when the engine runs. Or even better, with one that acts as a potentiometer to control flow rate according to temp requirements. Or am I overlooking something and is there "smart" stuff inside the pump that requires a controller? Anyone tried to build their own Arduino controller perhaps?
I'll have another browse on eBay tonight.
Last Edit: Mar 17, 2021 16:53:46 GMT by melle
madmog
Club RR Member Number: 46
I always had cooling issues on my Lancia engined Minor. I had already fitted as big a radiator as I could. Someone suggested two smaller electric fans instead of the one big and a Davies Craig electric pump. I never had a cooling issue again. From memory the electric pump and controller takes over the job of both thermostat and mechanical pump. You remove the wax thermostat and the guts of the old water pump body - if it needs to remain - to provide something for the existing hose to attach to. With the fans and electric water pump running I could watch the water temp drop quickly from too hot to too cold. I _think_ I added a connection to the Megajolt so fan and pump activated automatically from 5500 or 6000 revs. Before: After: Not much to see. I had this setup for about a year without problem then the car was nicked. Hence the aforementioned thoughts of a V4 engined Minor down the line. The pump hangs off the two hoses and is not mounted to anything else.
slater
It kind of depends in your reasoning for having the electric pump. Most people fit them for efficiency purposes. You loose the constant load on the engine and replace it with a pump you only need to run when you need to. It doesnt make sense to run the electric pump constantly and then restrict it with a thermostat etc.
If you only want it to help cooling in traffic pr whatever you would get away with it just running flat out all the time.
melle
South West
I've never had any issues with mechanical pumps on V4s, but I need the space for something else, hence I need a pump that doesn't need to be in line with the belt. A bonus advantage of an electric pump on a V4 would be that it no longer puts any strain on the balance shaft bearings, which are the engine's main weak spot. It's really easy to completely remove a mechanical pump from a V4, just hacksaw it off the timing cover. I'll modify one this weekend if I have time, I'll also delete the fan bearing in the process, which is a common mod when electric fans are fitted. Timing covers without a fan bearing exist, but they're very difficult to find and too expensive to hack up!
Last Edit: Mar 18, 2021 14:14:41 GMT by melle
Mar 18, 2021 10:11:31 GMT
I'm interested in doing something similar in the future but haven't done the research yet.
A long time ago I made a basic wiring loom for a college project that converted the Cortina to electric fan. it ran constantly at half speed using a resistor then when the car reached a certain using a temperature switch from a fiesta (can't recall the exact temp) it would go full blast till it cooled down again.
I wonder if you could do the same using a thermostat and set it for slow speed at cooler temps then full power for when it's hotter. it could be routed through a 5pin relay?
Mar 18, 2021 13:03:40 GMT
I did a bit of development work on electric water pumps for an OEM back in the late 90’s. I would definitely run a controller rather than leave it constantly running. A lot of engine wear is created when an engine isn’t run at the designed temperature so if you pick the wrong set point on your pump you’ll either run the engine too hot or too cold. The controller will optimise flow so that you have rapid warm up and optimum running temperature without having to worry.
One thing we did learn is that on the vehicle we used was that with the engine pump not working the car overheated as original pump had more than just an inlet and outlet to it. This meant that one port that was originally low pressure now became high pressure so the head had no flow. We had to block one port off to prevent this. This was a relatively new engine so older engines may not be afflicted with such problem.
Before fitting one though I would ask myself is it really worth it. If it’s for an engine with an inherent weak spot like you say, that’s great. If it’s for cooling issues I would generally think the issue is elsewhere as in the world of cooling it’s airflow, engine condition and in the realm of engine conversions,circuit design that’s the major factor.
melle
South West
Mar 19, 2021 14:00:47 GMT
Thanks all for some very useful input. I've just bought a used Pierburg pump on eBay, will look into controller options. Is anyone aware of any DIY/ Arduino controllers?
melle
South West
Mar 27, 2021 21:27:40 GMT
Is anyone aware of any DIY/ Arduino controllers? Google just answered my question (he uses a bigger pump, but the same principles apply I suppose): He says a few things in the video that I don't (yet) understand, but nothing a bit more googling won't solve I hope. Does anyone happen to have a spare plug for a CWA200 CWA400?
EDIT: After (partially) watching below video I realised the pump I bought on eBay is actually a CWA400. I guess it's way overkill for a wee 1.5 or 1.7 V4, not sure if there's any harm in using too big a pump in terms of power consumption? I'm not too clued up on electronics but very slowly learning, so please bear with me! The weight and dimensions are pretty much identical to the CWA200 according to the data sheets on the Tecomotive website, so if there are no real disadvantages I'll just stick with it.
Last Edit: Mar 27, 2021 22:02:25 GMT by melle
bstardchild
Club RR Member Number: 71
Mar 27, 2021 22:32:24 GMT
Wow that first video - seriously moves some water - I'd be worried it wasn't in the rad long enough to get any cooling
