Aug 16, 2022 12:59:43 GMT
Never mind. I had a thought so went out to the garage. Yup, the spare carburetor from the Pontiac fits. That one was worn but still ran the car ok. Makes me wonder how the Pontiac would run using the BBD instead of the WCD...
Aug 16, 2022 16:40:43 GMT
I decided to put the carb back together as I have a known good one for testing now. I went to align the lower gasket using the dimples created by the channels but I couldn't get things to line up or fit right. I flipped the gasket over and then reversed it. Bingo. RTV Man decided just to fill the gaps- one half of the idle circuit was open to atmosphere... If it's too difficult, ask an adult.
glenanderson
Club RR Member Number: 64
1966 Plymouth Fury 3glenanderson
@glenanderson
Club Retro Rides Member 64
Aug 16, 2022 18:54:30 GMT
If it's too difficult, ask an adult. Eventually though, adults tire of questions from idiots.
Aug 16, 2022 19:05:04 GMT
If it's too difficult, ask an adult. Eventually though, adults tire of questions from idiots. Create a better mouse trap, someone will invent a better idiot. Or something like that, at least.
Last Edit: Aug 16, 2022 19:05:15 GMT by PhilA
Aug 16, 2022 22:20:52 GMT
I'll just leave this here.
jimi
Aug 16, 2022 22:48:26 GMT
Actually sounds pretty good
Last Edit: Aug 16, 2022 22:49:28 GMT by jimi
Thanks. Gave it a little tweak, now it'll start up by itself just turning the starter, and it idles.
Last Edit: Aug 17, 2022 1:02:07 GMT by PhilA
jimi
Given what you started with, that's a damn fine achievement, well done.👍 Would interesting to see how it behaves with a car attached 😎
Aug 17, 2022 15:25:19 GMT
Given what you started with, that's a damn fine achievement, well done.👍 Would interesting to see how it behaves with a car attached 😎 That'll be a little while. First, no brakes at all. I might be able to adjust the parking brake to work. Second, not sure if I have a good radiator or not. Third, I believe I'm missing the gearshift linkage. Certainly the kickdown linkage is gone. I think I'll rebuild the BBD, then at least all the factory linkages match up. But yeah. We need to see if the car will move under it's own power...
Aug 17, 2022 16:01:35 GMT
Went rummage in the boxes to make sure I don't have the linkages (eBay expensive) and no. But I do have door locks (didn't realize that), which are soaking in oil to try and get them freed up. I need door handles though. And I have the screen wash pump. Which is probably seized solid. Phil
Last Edit: Aug 17, 2022 16:02:16 GMT by PhilA
Aug 17, 2022 17:41:38 GMT
Screen wash pump. Just that dirt came from the case alone, which isn't very complicated. It was seized solid. Finally managed to free it up, clean the dirt out of it that was completely blocking it. Now it runs again.
Aug 17, 2022 20:30:07 GMT
Did a little looking around the engine bay and found where it mounts. Makes sense, the battery tray goes to the right of my hand, the screen wash bottle to the left.
I have SECURITY. (Please don't reach in through the window, thanks)
Aug 18, 2022 13:12:19 GMT
Looking at that, it does show just how abysmal car security was in the sixties.
Item 1: Simple rod system you can jemmy in a moment Item 2: No steering lock Item 3: Hood doesn't lock, and takes a single wire to jumper the ignition on, and a screwdriver to start the engine.
The door locks in the Pontiac, from 14 years earlier are significantly more secure. Even the hood locks on that one.
I reckon, parked on the street, you could easily take off with this car within the "Gone in 60 seconds" timeframe.
Last Edit: Aug 18, 2022 14:16:15 GMT by PhilA
Aug 18, 2022 22:02:04 GMT
A box arrived. Headlight switch for the Fury, 2lb of .8 flux core and an automatic hat. Just in time for it to rain.
Aug 19, 2022 20:40:56 GMT
Ah, the sub-tropics. 3:27pm it starts to rain, big drops. It rained enough to soak everything. As suddenly as it started, it stopped at 3:36pm. Imagine a sauna, with a dirt floor. Thats the smell and feel of going outside. No welding right now.
Last Edit: Aug 19, 2022 20:41:24 GMT by PhilA
Aug 19, 2022 22:38:43 GMT
Zort, crackle. Rain went away long enough to put a bit of weld into the levers. Hopefully that'll do. Phil
Aug 20, 2022 19:29:38 GMT
Just bought some roll pins, a couple springs and a bolt with a long 1/2" shank. Reason? The door hinges are missing the rollers and the springs that hold them open. I found an old post on a Mopar forum which listed the correct spring off the shelf at Lowe's hardware. I'll cut the bolt down, drill it down the center and fit it in place. Hopefully then the damn doors will hold themselves open instead of closing on me as I'm trying to work in the car. Edit: Also, in addition to the correct locks, I have the correct door lock pins, too. Found those in a half shredded paper bag full of leaves in the workshop. Phil
Last Edit: Aug 21, 2022 1:33:31 GMT by PhilA
Aug 21, 2022 17:45:10 GMT
Cut down, drilled through. That was a lot of work, that's a grade 5 bolt.. Fitted in place, roll pin hammered through. Spring with one end bent through 90° to fit. The door holds itself open now. That'll do. Other side remains but that can be another day's work, it's too hot for much more today. Phil
Aug 21, 2022 22:20:41 GMT
New ignition stuffs. Fitted the new distributor cap, coil, rotor arm and amplifier module. Not bad. Needs an oil change again to flush the last of the watery gunk out. I've also got a gearshift linkage on order.
