Dec 26, 2021 15:18:22 GMT
There seems to be a wide variety of wobble bolts about with some claiming up to 2.4mm bridge per bolt
Has anybody used some with a wider gap? Whats the realistic maximum pcd from a 4x98mm that can be accommodated?
Thanks
Wobble bolt fitmentDez
@dez
Club Retro Rides Member 34
Dec 26, 2021 15:29:33 GMT
Realistically, 4x100.
4x4” (101.6mm) is too much of a stretch will all the ones I’ve tried, unless you want to massively oversize the holes in your wheels- which I don’t.
Assuming 12mm bolts/studs and Ignoring the actual seat, your wheels would have to have 15.6mm holes for the threads to line up straight on a 4x4” wheel. In reality they need to be a bit more as the seat doesn’t taper to nothing. By then you’re getting to the point where you’ve not got a lot of seat left on em. Not a good idea.
Dec 26, 2021 15:54:14 GMT
Any experience going the other way? (That came out wrong)
Any chance of 3 3/4" ?
