Air ride V2
Display ok with no lost pixels (starting to get a bit tacky as they all do with age)
Manifold with no leaks
Pair Unused Airlift Slam Gen IV Dominator Series D2500 - Single 1/2" Port. One Has a damaged thread.
Pair Unused Universal Air Aero Sport 02-ST-SB-14
Viair (need to check which model but from memory 444C) in Black minimal hours (less than 5hrs as the guy didn’t know how to use it)
2 sets of unused connectors so you can make up your own leads as you require, I have included full instructions on how to do this includes 2 compressor setup.
Pipe and fittings (¼ NFPT) – I can’t find these now but will do by the weekend. Pipe is black ¼ NFPT 30m.
Water Trap (working and not sludge’d up)
5 Gallon Air tank Looked inside and it doesn’t appear to have been used.
10mm Plates some drilled others plane more than enough to make end plates.
Pair of M14 sphericals with a custom made top plate to fit.
Over £1000 worth of parts. Not to keen on splitting unless you were taking a considerable portion i.e bags, Comp and Tank.
£850 ex delivery. (P&P would have to be calculated).
Based in Oxford, but work in Farnham and Have relatives in Windsor so can do all of those areas.
More photos here: www.flickr.com/photos/16913445@N08/with/52049614591/
20220503_202954 by creativeq, on Flickr
20220503_202938 by creativeq, on Flickr
20220503_202848 by creativeq, on Flickr
20220503_203033 by creativeq, on Flickr
20220503_203046 by creativeq, on Flickr
20220503_203138 by creativeq, on Flickr
