This Doka was built over the lock down period, it was originally flat bed Doka well known on the VW scene but needed a lot of work when I brought it, to bring it up to a higher standard. Firstly it needed a new turbo so that was replaced with a upgraded AET turbo. We then moved onto the rear bed, took it off as it needed stripping back so it could be re-painted. On doing that I stripped the old paint off the chassis and went right through the under side of the van, it needed a small amount of welding to the inner front wheel arches on both sides, they were cut out, repaired and then the arches was then re under sealed and painted, all the chassis was cleaned off and repainted with Hammerite then top coated and sprayed with black heavy duty spray.
When we took the flat bed off we came to the decision to fit a pick-up rear on there for more practicality and usage. Had custom mounts made, welded and fitted.
After all the body work was done it then went for new paint all over so the colour was changed to the new Audi Pure Grey. The door shuts are not done yet as show season had started so that will be done in the asking price or money knocked off if you don't want them done. Also had a load-liner fitted for extra practicality.
Engine Spec :-
Mileage: 146k (will go up as still being used).
MoT until February 2023.
2.5 tdi 102bhp but has the upgraded AET turbo which has also been mapped.
5 speed manual.
Top mounted intercooler.
Drives and pulls well.
Service done 2k ago will do another oil change soon.
Has the battery plastic covers so looks tidy under the bonnet.
Bonnet strut fitted.
Interior spec:-
Has been fitted with full Audi A7 S-Line leather seats with custom made rear frame, which is powder coated in black gloss.
Front seats are fully electric and work as they should.
Dashboard has been sprayed in candy red & the front door cards to match (This was done prior to my purchase of the van).
Wooden steering wheel & aluminium boss fitted but will only be included in the asking price other wise a different boss and wheel will be fitted.
New front fitted carpet, ready for the show season, and rear carpet fitted.
Exterior body:-
Rear bed was changed from the flat bed as stated. Has custom mounts welded and fitted rear lights changed to the rear body.
Full body respray in May to Audi pure grey (except door shuts).
Vito banded steels 8.5 on the front & 9.5 on the rear recently been re-powder coated.
The van has a front chassis notch which looked nice when down low but was totally impractical, so new bigger tyres fitted front and rear and lifted slightly on the front she now drives 100% better.
There is lots more done to the van too much to mention! There is also build page in Instagram @grey_doka_t4 so you can see loads of the work done.
Any queries please feel free to contact me.
Engine Spec :-
5 speed manual.
Interior spec:-
Exterior body:-
