Figured I'd least do a thread on here on my daily driver, a 2002 BMW 3 series in touring flavour with the M54B30 engine as standard.
From what i've dug up , this is one of about 180 Sport manual tourings left on the road, making it quite a rare beast.
Having owned it since December 2014, at which time I picked it up from a dealer in Nottingham for just under £5k and on a insanely low milege of 54,900 miles I've since done over 70k since including several trips to the continent including Stuttgart, Spa, Nordschleife, and Le Mans. It's managed a 9:42 BTG time with video footage, gets at least a 2-3 track days a year, last one being at Brands Hatch Indy and been been driven by a youtuber known as Jimmy Broadbent whom commented the car is well balanced and a decent car.
I've also re-engineered the vehicle extensively in the 8 years I've had it and it's evolved into something that on first look doesn't stand out, but if you looked closer, the details hint that something is definately different about the car. It certainly gets a few looks on track days as it's the last thing you expect to be turning some reasonably quick laps and will give Porsche Boxsters and Mk1 elises a good run for their money
I did attend the Mallory Park meeting but never made it into the show due to someone not knowing the model came out in 1997 as it's a grey area... Ah well , next time perhaps?
Specification is below
Engine
 M54B30 3.0 Straight six
 Fully balanced incl flywheel and balancer
 Achilles Oil pump upgrade
 ARP Rod bolts
 ARP Head studs
 ARP Main Cap studs
 VAC Motorsport Bearings
 Alpina B3 Harmonic balancer
 Baffled Sump
 K&N 57i intake with gold heat tape for additional heat protection on shield
 CSF high performance radiator
 JustDeutsch V1T Camshafts
 Modified E46 M3 System, 200 Cell CATs and Eisenmann Rear silencer.
 Remapped on Rolling road
 261bhp @ 6214rpm
 333Nm @ 3391rpm
Transmission
 E36 M3 Evo 6 speed gearbox
 ECS single mass flywheel conversion inc E34 M5 Sachs clutch
 E46 M3 Gearbox shift linkage
 E46 M3 gearbox support
 E46 M3 propshaft + custom spacer
 Gripper plate type LSD – 60/35 ramps with 8 plate clutch pack. (1.5 way)
 DSSR selector rod
 Turner Motorsport short throw shifter + Rally shifter extension
 HEL Clutch line + Delay valve delete.
Wheels & tyres
BBS CHR Staggered setup
 Front - 8 x 18in
 Rear – 9 x 18in
Tyres are Michelin PS4 all round(F/R)
Suspension
 KW V3 coilovers
 H&R roll bars (M3 specification)
 Meyle heavy duty front arms
 Stock front top mounts + Turner Motorsport camber plates.
 Powerflex bushes
 Front lolipops
 RTA bushes
 Subframe and diff bushes
 Rear damper mounts
 Powerflex rear camber arms
 BMW Ball joint swap in lower rear bushes in RTAs ala' M3 specification
Brakes
 Front - Porsche 986 (Boxter 3.2) 4 pot conversion
 Front - BMW M3 CSL 2 piece discs (345mm)
 Rear – Stock callipers and discs
 Pads all round – Ferrodo DS2500 pads
 HEL Stainless lines all round
 ATE TYP200 fluid.
 ECS Brass slider upgrade for rear calipers
Interior
 Royal Steering wheels retrim in alcantara leather, M colours stitching + blue
center line
 Royal steering wheels – Gearshift gator and handbrake with M colours stitching.
 Original Leather interior with driver's seat swap to Sparco Evo seat
 Sony CD / MP3 / USB / DAB radio – as original CD changer failed.
 Red needle and bezels on clocks upgraded to Alpina versions.
Exterior
 Mystyle front Clubsport front lip spoilers in Carbon fibre
 Mstyle rear valance in carbon fibre
 Full respray in original metallic Orient Blue.
 Front wings repaired and rustproofed
 Rear arches cleaned and rustproofed.
Misc
 Rear subframe re-enforcement kit from Radish Motorsport installed
 Rear end completely cleaned and rustproofed.
 Stereo replaced for Sony blue tooth and USB unit.
Some pictures below:
Feel free to ask me questions and advice, given my day job is working with HV batteries, I have worked for companies like Aston Martin, Dunlop Motorsport, Caterham Cars and currently with Cummins.
Engine
 ARP Rod bolts
 ARP Head studs
 Baffled Sump
 261bhp @ 6214rpm
 333Nm @ 3391rpm
Transmission
 DSSR selector rod
Wheels & tyres
 Front - 8 x 18in
 Rear – 9 x 18in
Suspension
 KW V3 coilovers
 Powerflex bushes
 Front lolipops
 RTA bushes
Brakes
 ATE TYP200 fluid.
Interior
center line
Exterior
Misc
